Started Embraer
Started Embraer
Posted by Don Stauffer on Saturday, August 15, 2015 9:01 AM
I had started the A320 on a clean bench, only kit on bench.  I usually like to have two kits on bench, so I can work on second one while I wait for paint or glue to dry on first.  I started the Hasagawa Embraer E170 that I had recently received.  What a marvelous kit!
It has the centerline antenna molded as part of the fuselage, a feature I do not like, and had pinged Revell for doing that on the A320.  But in the case of the Embraer it will not be important.  The fuselage sides fit together perfectly!  I don't have any paint or primer on it, but I cannot feel or see any offset along the fuselage center seam, and cleanup will be absolutely minimal. If any offset is there, it must be a fraction of a mil, and the seam fit is very tight!  Lots of finely molded detail too!
    September 2012
Posted by GMorrison on Saturday, August 15, 2015 9:33 AM
Sounds good. Cut if off, put it where you wont lose it.
Posted by Lufbery on Saturday, August 29, 2015 9:35 PM
Please post some photos when you can.
Regards,
-Drew
Build what you like; like what you build.
