Im building a 1/200 scale Hasegawa E4-B for Boeing GB. Its been a good while since I built an airliner removing top seam
Nick.
more seams to remove form engines and detailing engine fans .Primer is next I hope seams are gone
Nice! I havent seen a built up kit of this recently.
No bucks, no Buck Rogers
wings and stabilizers in place. Primed, putty and more sanding
ok its been awhile progress has been slow with stuff around the homestead. Here is my 1st coat of model masters classic white now drying time for next coat
Lookin real *** and span. Thats some glossy acrylic you got there.
thank you. Im using enamels its like painting a car with wings
That's looking really good.
That white looks like it would be close to this shade:
I've got a 1/24 resin model of this race car headed my way. That Classic white might work.
Gary
"All you mugs need to get busy building, and post pics!"
That would look awesome make sure you thin the white a little more then 2 % several light coats gloss white enamel can be a pain to spray
Looking good!
I'm re-starting the old Revell 1/144 E4B but doing it as a Northwest -200 instead. I had started it, messed something up so went back to square one. ;) Draw Decal had the scheme of the NW plane I came home from Desert Storm on so decided to model it.
Link to my built kits: http://s37.photobucket.com/user/kg4kpg/library/Planes?sort=3&page=1
I haven't built a airliner since 1978 its a lost skill set thats slowly coming back that dc-9 looks good in nasa colors
Ray
my compressor is now FUBR new one on order. New task to paint intake rings on those tiny engines 1st then mask
got my new compressor just in time .Now to place all of these tiny antennas along the top and bottom off fuselage then another coat of gloss white
getting all those little antennas in a row
Almost done with all the antennas next to work on the intake rings on the engines 1/200 scale got to love them
I done with those little antennas now another coat of gloss white
ok moving along on those engines . I also used tamiya masking tape for curves the 3mm size it works great to bad it's white in this case
there it is only three more to go
Thats solid work youre putting in there Crown!
Devil Dawg
On The Bench: Tamiya 1/32nd Mitsubishi A6M5 Model 52 Zeke For Japanese Group Build
Build one at a time? Hah! That'll be the day!!
masking and painting lead edge wings, stabilizers and tail fin with model masters non buffing aluminum.
finished painting lead edge of stabilizers and tail. next the decals for top of flight deck and nose its see if it works
did both side stripes. wasnt as bad as i thought more to follow
almost done with decals a few more
The landing gear and engines in place need some clean up some small stuff here and there
the E4-B is completed all those tiny parts thank you tamiya cement !
That's some beautiful model building there!
Bravo!
thanks guys it was a different build but fun. my next one is hasegawa learjet in 1/48.
