Please turn off all electronic divices, and make sure seat backs and trays are upright and in the stowed position...
One of the thing I read in the kit reviews was that there was a bit of "texture'" on the part surfaces. I have not inspection all the parts yet but I found that parts of the fuselage has more than a bit. It gets worse as you get closed the mating surfaces. Under the windows is pretty smooth, above the windows you can see that it's starting to get worse. It gets tot he point it looks like the parts were sand cast instead of injection molded.
Anytime I think of something "new" I always figure of I could think of it, someone else did already but I came up with this. Gluing a plastic strip on the inside and filling all those holes seemed tedious. This was minutes. the longest part was mixing the resin. Just a few pinhole to fill.
