broken gear
    March 2016
broken gear
Posted by ardvark002 on Wednesday, February 8, 2017 9:08 PM
Hi all, I dropped  one of my 1/48 builds, broke both gear off. Not enought surface to reglue well. Any suggestions?  Was a nice F8F-2  Smimnoff racer. Very sad.  Any help would be appericated.  Thx. Aardvark
    November 2003
Posted by mississippivol on Wednesday, February 8, 2017 9:18 PM
You can drill out the mounting stub and also the gear leg, then use a piece of very stiff metal wire or rod to pin it back on. I've had to do that several times over the years.
Posted by jeaton01 on Wednesday, February 8, 2017 10:31 PM
Yeah, do that.  Gel super glue works good for this method.
John
Posted by Don Stauffer on Thursday, February 9, 2017 8:51 AM
I concur on trying the drilling and piece of metal, but if that doesn't work, I did an article a number of years ago for FSM on working with metal, and described making a gear leg from brass tubing.  I will try and find the issue number.
    March 2016
Posted by ardvark002 on Thursday, February 9, 2017 9:42 AM
thanks for the ideas, appericate . Aardvark
    January 2010
Posted by CrashTestDummy on Thursday, February 9, 2017 3:53 PM
Or better, order an aftermarket metal landing gear set for the thing.  I'm sure someone makes a set.
Gene Beaird,
Pearland Texas
G. Beaird,
Pearland, Texas
    March 2015
Posted by Toshi on Saturday, February 11, 2017 3:24 AM
Do an inflight model if possible.
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
    March 2008
Posted by kg4kpg on Tuesday, February 14, 2017 12:49 PM
I can concur on the drill and wire technique. I had to do it to my 1/144 A380. Worked like a charm. That F8F strut is a good bit thicker than what I had to drill, I'll bet it would work really well.
Chris
    January 2003
Posted by leemitcheltree on Sunday, February 19, 2017 3:01 PM
Ardvark, I absolutely agree with the drilling and pinning of the broken gear - sorry to hear about the accident!!!
Depending on the scale, I've used guitar strings, pieces of sewing needles, sewing pins, and thin stainless rod.  The toughest thing is getting both drilled holes lined up perfectly.....I often drill the holes a few sizes larger than the pin, so when I put it together, I have a little "wiggle room" to get the best alignment.  Slow setting CA seems to work best for me.
Good luck!
Cheers, LeeTree
Remember, Safety Fast!!!
