Revell Germany ERJ 195 to 190 project
    May 2016
Posted by B-1 CrewCheif on Wednesday, May 24, 2017 8:33 AM
Hello all, so idecided to do a really quick build of Revell Germanys ERJ 195. This is my first airliner kit and i figured it would be an easy one to do since its so small and simple. So to start things off I decided i would convert this over too a ERJ 190 so i could use the "Frontier Airlines" decals i have. To do this mod it only requires you to take out 2 windows to shorten the fuselage.
So right away i built the airplane and marked my cuts. I did and initial marking cut with my rotary tool and then actually cut it with a hobby saw. after the cut it was a bit uneven so i layed some sand paper down on the table and sanded the fuselage flush and smooth.
Right after i was able to glue the fuselage pieces together and I now have a ERJ 190.
My plan for this build it simple. After i fill and sand all the seams in the next post im going to paint the fuselage white, and the wings grey, and then do a light clear coat and aply the decals. Once the decals are on im going to clear the aircraft with a Urethane clear like whats used for car clear coats to give it a really good shine and also give it some protection.
Thats all for now. Thanks for reading
Tyler.
On the Bench: 1:32 Roden Stearman, 1:35 Orochi M3A3 Bradley, 1:6 Mandalorian figure
    December 2009
Posted by scotty100368 on Sunday, June 11, 2017 8:43 AM
Tyler,
That conversion guide is not correct. I have modified it with data sourced from Embraer.
Essentially, 1 window forward of the wing and 2 windows aft!
Scott Garard
Queanbeyan NSW
Australia
    March 2015
Posted by Toshi on Tuesday, June 27, 2017 8:13 AM
Everything is looking good, keep up the good work!
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
    April 2020
Posted by JON8A on Tuesday, April 14, 2020 11:21 PM
Why do you say that??, i scaled it down acording to the real model kit, i can supply you a scaled copy wenever you like it
    December 2009
Posted by scotty100368 on Tuesday, April 21, 2020 3:41 AM
Jon,
I confirmed the actual fuselage lengths from various sources:
E190 is 36.24m (1/144 scale is 25.16cm)
E195 is 38.65m (1/144 scale is 26.84cm - not 26.40cm!)
I measured the kit parts myself, and they correlate with my data.
The fuselage difference being 2.41m (1/144 scale is 1.68cm).
One-third of the stretch was forward, leaving two-thirds of the stretch aft.
So, 1/3 x 1.68 = 0.56cm forward (not 0.4cm), 2/3 x 1.68 = 1.12cm aft (not 0.7cm).
Your incorrect E195 length was what mucked up all the math...
Cheers!
Scott Garard
Queanbeyan NSW
Australia
