FINISHED: DesTROYer’s 1/144 Zvezda Boeing 737-800 QANTAS Retro Roo II
    May 2018
Posted by DesTROYer on Saturday, September 15, 2018 5:35 AM
This evening I started on another new project, a Zvezda 1/144 Boeing 737-800 that will be done up as the QANTAS Retro Roo II.
Straight out of the box the kit looks great. The fuselage and wings go together real nice. There are very fine panel lines with I think will come out beautiful under a coat of paint and the flush fitting smooth windows will save a lot of time on filling them and sanding smooth I think.
It’s almost falling together. This is how far I got just after only an hour or so's work.
    May 2018
Posted by DesTROYer on Friday, November 2, 2018 3:53 AM
OK, Wow.  It's been a while since my last update, but that said it has been a while since I did any work on this Retro Roo too, but as work has stalled on the 1/35 Chinook I'm working on as I wait for a part to arrive before I can start on the painting, I've had the opportunity to get some done. When last we met, I had completed basic assembly of the fuselage and wings.  Well over the last few days I've managed to get some paint down and the engines mostly assembled.
Tamiya fine white prima for the white sections, which I will give a light sanding too before applying a tamiya gloss clear coat.
and Tamiya Sky Grey for the Boeing grey sections.
More to follow in the next couple of days.
Posted by keavdog on Friday, November 2, 2018 7:42 AM
Coming along - looking forward to the finished livery
Thanks,
John
    May 2018
Posted by DesTROYer on Sunday, November 4, 2018 12:20 AM
Yesterday and today have been most productive.  Last night after dinner I was able to put down a gloss coat to Tamiya clear, which allowed me this morning to begin decals.
Though made for the Revell 737-800, using the Hawkeye set on the Zvezda kit works pretty well. On this side I started at the rear and worked my way forward.  The length is right and the windows line up pretty well, but where the cutaway for the cockpit windows ends up is a little bit off.In hindsight I should have started there and finished at the rear. A bit of playing around and I got it to work out in the end.
As with the other side, I cut up the long cheat line into inch long pieces, as I found that last time, this time however I did start at the front of the plane and worked my way back and got a much better fit around the windscreen.  The Anti-glare panel decal covers up the join between the two pieces.
Keeping at it with a crappy B-Grade Movie on in the back ground, I managed to get through all of the decals in a couple of hours, even managing to get the engines and tail planes glued in place.
I still need to install the lights in the wings, seal the decals with another gloss coat and paint up a flying Rat logo on the base, but its getting closer to finished.
It already looks pretty good beside Retro Roo James Strong, if I do say so myself.
    September 2017
Posted by kensar on Sunday, November 4, 2018 8:44 AM
Looks great Troy!
What is the wingspan of the model?
Kensar
    May 2018
Posted by DesTROYer on Sunday, November 4, 2018 9:28 PM
Hi Kensar, the wingspan is 260mm.
Got back into it this morning starting off with the display stand.  Using the Silhouette cutter I made up some masks and after spraying a white base on the stand I applied the mask and set to work putting the colours down.
Some minor touch ups were required, but it came out just as I had hoped.
Then after a clear coat was applied to both the stand and the model, were were done. So I now present to you my finished Boeing 737-800 Retro Roo II.  Zvezda 1/144 737-800 kit, Hawkeye decals, Tamiya paints.
Looks pretty good next to its stable mate.
    September 2017
Posted by kensar on Monday, November 5, 2018 6:33 AM
Nice pair of airliners.  I like the in-flight portrayal.
Kensar
    January 2003
Posted by leemitcheltree on Thursday, November 22, 2018 10:14 PM
Just lovely, mate.
I worked for Qantas for 9 years...near the end they cut the wings off the Roo.   We called it "The Flying Rat".
The classic 707 and the early 747's were the prettiest of them all.  Your models are just awesome!
Cheers, LeeTree
Remember, Safety Fast!!!
    May 2018
Posted by DesTROYer on Thursday, November 22, 2018 11:07 PM
Thank you.
    June 2017
Posted by fotofrank on Friday, November 23, 2018 5:40 AM
Very well done, Troy. I'm considering a 737-500 from Daco/Skyline. Did you have any balance issues putting the airplane on the display stand? Did you have to add weight to the stand to support the model? I have those same stands and I'll use one for the 737 I plan to build.
OK. In the stash: Way too much to build in one lifetime...
Posted by gregbale on Friday, November 23, 2018 9:11 AM
Oh, that is bloody gorgeous!
Really eye-catching, and the stand is the perfect accent. Well done!
Greg
George Lewis:
    May 2018
Posted by DesTROYer on Friday, November 23, 2018 12:19 PM
fotofrank
Thanks. No on both questions. Once the plane was assembled I just found the center of gravity by ballencing it on my finger, then cut the slot For the stand. No weight was needed in the stand.
Posted by Don Stauffer on Saturday, November 24, 2018 6:54 AM
Love them both.
    July 2014
Posted by Bakster on Saturday, November 24, 2018 9:31 AM
Very nice. They look great!
    January 2010
Posted by CrashTestDummy on Monday, November 26, 2018 12:13 PM
DesTROYer
<SNIP>
<SNIP>
Nice work!  Did you use the Silhouette-supplied graphics app to make the mask?  My wife has a Silhouette, and I've thought about making masks, but just haven't done so yet.
Gene Beaird,
Pearland, Texas
G. Beaird,
Pearland, Texas
    May 2018
Posted by DesTROYer on Monday, November 26, 2018 12:27 PM
G’day Gene, yes. I found the logo I wanted to use on google and imported it into the silhouette software, traced it, spent an hour cleaning up all the lines so only the minimum plot points needed were there and set it to the cutter.  I did get the advanced software package pretty early on, so I can’t remember how much you can do with the free one, but I’m pretty sure you can do most of that with the free version.
    January 2010
Posted by CrashTestDummy on Monday, November 26, 2018 12:43 PM
Thanks for the quick reply!  She's pretty deep in the card-making and scrapbooking hobby, and just recently updated her Silhouette to the 12" model, and has a subscription with them for the fonts and forms, etc., so she may have the advanced package.  I'll have to ask, though.
Gene Beaird,
Pearland, Texas
G. Beaird,
Pearland, Texas
