I opened my B-17C kit- surprise!
    September 2012
Posted by GMorrison on Tuesday, October 2, 2018 4:14 PM
Quite a while back I added the Colin Kelly B-17 to the stash. There was a question posted here about details of the radio operators hatch. Having no clue how the thing worked, and not finding much online, I figured I'd dig out the kit and see if the parts offered any clue.
And there it was, in the bottom of the box. A Maquette B 307 kit, or at least the fuselage halves, bought separately andthe project for which the B-17 was purchased.
I don't know if I'll ever get to it, and the dang thing STILL smells of cigarette smoke from the eBay seller.
But certainly I am pleased I never threw it away.
Bill
Posted by jeaton01 on Wednesday, October 3, 2018 12:15 AM
Nice surprise!
John
Posted by Don Stauffer on Wednesday, October 3, 2018 9:18 AM
That Maquette kit is the worst kit I ever tried to build.  I gave up, and bought a B-17 kit so I can scratch the fuselage and build a 307.  That Maquette kit had fuselage halves that did not match.  The hieght of one side was considerably higher than the other side.  It would take so much putty and filing that it looked like fixing that would change the fuselage contour markedly.
    September 2012
Posted by GMorrison on Wednesday, October 3, 2018 10:18 AM
I think that's what got me. Maybe it would be possible to cut a strip out of the longitude beltline on one side.
Posted by jeaton01 on Thursday, October 4, 2018 11:19 AM
I have an Airmodel vac that may be a better start, but it's not that hot either.  Someday.
John
    September 2012
Posted by GMorrison on Saturday, October 6, 2018 12:07 AM
Bondoman had a thread in "Aircraft". I'll take his model from there.
http://cs.finescale.com/fsm/modeling_subjects/f/2/t/117882.aspx
    September 2012
Posted by GMorrison on Sunday, October 7, 2018 5:45 PM
The 307 did not have turbo chargers, correct?
Posted by Don Stauffer on Monday, October 8, 2018 8:49 AM
GMorrison
That is true.  The nacelles have to be modified to remove the turbos.
    September 2012
Posted by GMorrison on Monday, October 8, 2018 10:56 AM
Don Stauffer
And also the intercooler cooling air vents, those four slots behind each engine on the top of the wing. The rebuild of the four bottom halves looks to be a little work.
    September 2012
Posted by GMorrison on Monday, October 8, 2018 11:10 AM
Not the best photo, but these are the remedies I came up with for the poor fit.
The starboard side was larger top-to-bottom than the port side, by about 1/16" right behind the cockpit. They fit together pretty well back at the tail.
I made a saw cut along a panel line from the upper rear corner of the windscreen, back to the passenger door on the port side. Then I clamped the two sides together and aligned the top and bottom to fit right. That created a spread gap in my saw cut of 1/16" right behind the cockpit, tapering to closed at the door frame.
I glued a shim behind the cut for it's length, to hold the open gap, and then filled it with Bondo.
I also filled the windows, which are rough recesses for no reason I could figure. My decal set from Mike at Vintage flyer has window decals, which is usual in his sets.
There's a lot to do, but one step at a time.
