Seeing Clearly , or Why hide all that work ?
    June 2014
Posted by Tanker - Builder on Friday, March 22, 2019 9:09 AM
Biz-Jet builders, Attenzione !
     Here's a tip to help you show off all that work on your interiors .When you are ready to close them up ,tape them together well and do this .Find some Baggie material ! Yup,Baggie Material . Stretch it as tight as you can over the fuselage top and tape it down tight !
     Now take some of the Water resin from model railroading . Pour it gently over this impromptu mold to the bottom of the window line,let dry .Now add another layer. Let dry well. Now carefully remove this from your plane .
       Now mark the fuselage at the point where you want to show off stuff . Cut the plastic and resin to fit and drop it into place .Fastening it with Aleens or Watch Crystal cement . Now the plane's lines are not compromised and you can still decal it and also see all the work inside . Catchya Later   T.B.
    September 2012
Posted by GMorrison on Friday, March 22, 2019 9:45 AM
A photo would be nice so that we cansee what that looks like.
    July 2008
Posted by Est.1961 on Friday, March 22, 2019 4:15 PM
Ditto
    September 2018
Posted by Challenger350Pilot on Monday, March 25, 2019 2:40 PM
ZOIKS! What a great idea! Send a picture as an example and teach us how!
    May 2016
Posted by B-36Andy on Thursday, March 28, 2019 10:14 AM
Man! This is really thinking outside the box!
I'm not sure how this all works---Could you expain more detail? I am willing to try a test fusalage. Does the baggie get taped to the outside over the entire fusalage? won't the resin run off?
