Thanks,
Chris! Id like to build a whole army of em, actually. LOL.
Mike,
Thanks! Youre very kind. I used Tamiya enamels for all the figures, adding about 15-20% flat base for each color mix to get dead flat results. The colors I used:
1. Flat Green (XF-5, 80%) + Flat White (XF-2, 20%)
2. Red Brown (XF-64, 75%) + Flat Red (XF-7, 20%) + Flat Black (XF-1, 5%)
3. Buff (XF-57, 60%) + Khaki (XF-49, 30%) + Desert Yellow (XF-59, 10%)
4. Flat Black (85%) + Sky Gray (XF-19, 15%).
I actually dont prime my figures. I dont layer the paints, either. The reason is at 1/35 scale too much paint will cover up most of the details. Creases, lapels, pockets, etc. lose their crisp edges, so uniforms start looking thick. I apply each color in accordance with the Woodland pattern right away. I usually start with the green mix, then the red brown, then the buff/khaki mix, and finally the black mix. Because of the system I use you cant begin painting the lightest color first. It would be difficult to see.
Great idea on the Marpat, by the way. Im gonna try to look around for a shirt, at least. And then, maybe, psyche myself up.
