Black prince, Help!
    October 2005
Black prince, Help!
Posted by sawdeanz on Monday, February 23, 2009 4:32 PM
If anyone has built Verlinden's Black prince kit, I was hoping you would post here and tell me where everything goes. Specifically there is a shield and two strap looking parts ( i assume they go with the shield) and they arn't on the picture and there are no instructions. I'm guessing the shield goes on the back? But I have little experience in knights so i don't know how it should look.
    July 2007
Posted by ski4jeepin on Monday, February 23, 2009 6:29 PM
Hey there Sawdeanz,
     You're right, the shield does go in back...
As for the "two strap looking parts," the only thing I can think of would be the boot spurs. If you look closely at the box-art you can kina see the spurs...
Good luck with it!
Model building isn't about patience, it's about passion.
    October 2005
Posted by sawdeanz on Monday, February 23, 2009 7:54 PM
Thanks, yeah that helps! Great figure by the way. Is the shield symbol a decal? Cuz I was also considering changing the emblem but I don't know if I can in times sake since it will be a gift. And yeah, the spurs were what I was thinking of. This also happens to be my first figure in this scale, so I'll post the results for you.
    July 2007
Posted by ski4jeepin on Monday, February 23, 2009 8:11 PM
Thanks for compliment. Yeah, the crest on the shield is a decal. I just filled in the engraved lines and painted the shield, then applied the decal. I also left off the shoulder boards. I think this is a good choice for a first figure since there's no flesh tone to bother with. Can't wait to see the finished product!
Posted by renarts on Monday, February 23, 2009 8:32 PM
The figure is set up out of the box to have the shield slung across its back. The diagonal strap that encircles his chest is the shields guige strap. This strap served two functions. One as depicted on the figure, allows the shield to be slung across the back, the other is to help secure the shield so that it isn't dropped or pulled away from the owner.
Normaly there would be two or three straps connected to the shield that suspended the shield from the forearm and wrist and palm. In the case of a center bossed shield (a shield with a dome in the center) the "handle" would be behind the boss. This is a slightly different configuration and way of handling a shield.
The boards mentioned by ski4jeepin are called ailettes (french - little wings) and are a heraldic device more than anything else. They were made of leather, stiffened parchment and or thin wood and had the owners arms or badge painted on them. These were laced through the mail or armor and simply tied on.
A decal would work fine for the shield if you weren't inclined to try and paint your own heraldry. Apply the decal as you would on a piece of armor or aircraft. Some painted highlights over the decal will give it a painted look. If you want to try and paint your own heraldry, its an easy enough process to do. Heraldry is pretty easy for the 14th c. and the arms of a shield or surcoat rarely include a full achievement. Usually a field (color) possibly a pattern or division (cross, pale, fess, etc.) and a charge (a component of the owners heraldry). This was the practice and was usually the badge or livery of the owner. Same for the ailettes.
Andrea makes a transfer set of heraldic images and there is a company now that is releasing masks (stencils) for helraldic use.
    April 2008
Posted by smeagol the vile on Wednesday, February 25, 2009 10:10 AM
Thats the one thing I dislike about verlinden kits, there gorgeous and all, but no instructions, you have to figgure out where the stuff goes yourself.
