suggestions on making camaflouge uniform neede
    June 2009
Posted by E. Jose on Saturday, June 6, 2009 12:51 PM
        there are so many infantry kits i have been planing to buy, but most of them have 2 color and 3 color camaflouge. I am mostly used only to uniforms with one color. besides i only started in fantry 1 month ago.
        so what i need are suggestions on painting 2 color camaflouge & 3 color camaflouge uniforms.
    July 2004
Posted by stikpusher on Saturday, June 6, 2009 1:09 PM
A good method is to first research the particular type of camoflage pattern that you are trying to replicate. You will see that there is usally a base color (usually a tan or light green) on which the pattern is applied. Paint that color first, then usualy work from lighter to darker colors in your pattern. This will work in most cases except for a few specific types of camo uniforms.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    January 2009
Posted by camo junkie on Saturday, June 6, 2009 2:47 PM
Sign - Ditto [#ditto]
"An idea is only as good as the person who thought of it...and only as brilliant as the person who makes it!!"
Posted by ajlafleche on Saturday, June 6, 2009 3:09 PM
Find the pattern you're looking for on-line and print a sample. Then match the colors. Next, get a flat sheet of plastic or even an index card and practice painting the pattern close to the scale size you need. When you're happy with the results, replicate that on your figures. Remember, unlike an expensive dress suit, the various parts of material are not matched so you should treat each replication of a picee of material as separate from the rest,  i.e., stop the pattern at the back seam, paint each pocket patch slightly offset from the back ground material.
