OK gennulmen (and maybe even ladies - who knows?), I'm movin' on with the figures. After priming sarge's face and hands with Humbrol 63 I left the parts to dry for several days (just because I didn't feel like touching it). Then I was doing a dark brown oil was for my dio and had a little left, so in an impulse I used it up on sarge. When that was done I had no other option as to proceed, to get that wet-on-wet effect. I used Humbrol flat white mixed with a little fleshtone for the highlights. Here's what it looked like after the shading:
Then I left it to dry for a day or two and went on and painted the lower lip, eyes and eyebrows. For eyes I used light gray for the whites and dark gray for the iris (and for the eyebrows). I also applied minimal quantities of black future wash to the eyes and the lips so they look a little wet. Now the sarge looks like this:
Motivated by results I liked, I went on to the first ammo loader figure. I used the "leaning tanker" from the same Tamiya command figure set as basis. Out of the box he looks like this:
Let's see what I can do out of this. First I chopped the head off (but carefully - those tanker helmets are hard to come by) and drilled the neck out. I found a nice head in the Dragon set number 3305 U.S. MARINE (TET OFFENSIVE, 1968) - it was intended for the guy caring his wounded buddy on his back. I was able to mate the torso and the head. I inserted a shim between torso and legs, to make the figure bend a little lower. I also modified the legs with cargo pockets for the trousers, again using my old trick with plastic sheet and filler. The Tamiya figure can really benefit from a through cleanup. Using the tip of the blade you can do wonders on the jungle boots, for example. Then I started putting the man together using nitro solvent mixed with plastic filler. This way I get a joint that is posable for about half an hour and I can shape the excess with brush soaked in solvent to smooth the joint, so that when it dries no filling is necessary - just filing. The downside to it is the joints need a few days to cure completely - but I have enough other work to switch to, so it's no big deal. That's what I got at this point:
I think the guy's name is Brownie. That still leaves one loader to do. Please write me what do you think, and have a nice day
Pawel
