aircraft figure faces
    July 2009
Posted by Blackbelt2 on Wednesday, January 6, 2010 6:52 PM
I just downloaded Rafe Morrissey's Easy aircraft Figures in nine basic steps and i have a silly question? Each time you lay a coat of paint, steps 1,2 & 3, should you wait for each coat to dry or should I put the 3 face shades on at once along with the thinner wash? This is my first attempt at figure painting so please forgive my ignorance.
Karl
    January 2009
Posted by camo junkie on Thursday, January 7, 2010 2:23 AM
not sure what type of paints our using (and im unfamiliar with rafe morrissey's work) but if they are acrylic they should dry almost instantly and if they are enamels you'll want to wait a good 24 hours b4 applying.
"An idea is only as good as the person who thought of it...and only as brilliant as the person who makes it!!"
Posted by ajlafleche on Thursday, January 7, 2010 7:26 AM
Well, I'm not willing to pay, sight unseen, for any X easy steps to anything, especially something I know that achiving good results and easy are virtually mutally exclussive. A bit of explanation of what this guy is saying might be in order. There are those of us who've been painting figures for years and still need to take time to get it right, and no part of a figure need more getting right thanthe face since we are pretty much hard wired to recognize the human face.
    March 2008
Posted by EasyMike on Thursday, January 7, 2010 12:23 PM
Have you tried contacting Rafe Morrissey?  You're using his method; he should be able to explain what he does.
Why not paint the way you like?
Smile
    January 2009
Posted by fermis on Thursday, January 7, 2010 12:56 PM
 Can't answer your particular Q? But, I've tried a few of those "tried-n-true" methods, with pisspoor results.
This pic is of my first large figure, I use the same method on the small ones. I simply painted the fleshtone (no primer, nothing fancy) and drybrushed some highlights and shades of flesh. He's been to 3 shows and taken one 2nd, and two 1sts along with a "Best Fig". Not too bad for my first fig and a very simple method to boot!!!
001-3.jpg picture by fermisb
    July 2009
Posted by Blackbelt2 on Thursday, January 7, 2010 2:32 PM
Thanks for the help! What paints do you use acrylic, enamel or oils on your faces?
Posted by ajlafleche on Thursday, January 7, 2010 2:57 PM
Blackbelt2
See my post here
    January 2009
Posted by fermis on Thursday, January 7, 2010 6:23 PM
 I use only enamels.
    July 2009
Posted by Blackbelt2 on Friday, January 8, 2010 12:33 PM
I am using enamels but from what I read in the forums, you can use either one. I guess it depends on the user.
    October 2009
Posted by krow113 on Friday, February 26, 2010 1:52 AM
Nice job on the B-17 crew -see Earle
Thank you ,Krow113
Posted by Gamera on Friday, February 26, 2010 2:17 PM
Sorry I'm not familar with the article either but if he uses the 'blending' and uses oils he probably means wet. However; if he uses the term 'layering' and acylic paints he probably means to let them dry.
I've seen two styles used- since oils dry slowly the blending style has the painter blend or feather the edges between the different shades together.
With acylics you thin them till they're translucent and then layer several coats in order that the different translucent coats build up from coat to coat to get a smooth transition. This is a gaming figure website but Anne Foerster gives a better explanation than I can.
http://www.reapermini.com/TheCraft/7
Frankly with enamels you've got me, I have no idea...
