Mounted German soldier
    December 2008
Posted by psstoff995's lbro on Sunday, January 10, 2010 6:17 PM
Working on a mounted German soldier, I have the first coat of oils on the horse and the German and it's my first time using them.
How does the horse look so far? I don't know what kind of horses they used.
-Will young modeler Test fit master
Posted by ajlafleche on Sunday, January 10, 2010 6:52 PM
I'd have gone less for a bay color and more of a deep brown, burnt umber, for example,  but who's to say?
In the first picture, iyou need ot do a good deal of clean up. The joint between the neck and torso will need a lot of putty. There also appear to be some glue wspluges on the horse's right shoulder. It looks like there's still a seam down the middle of the haunch behind the saddle. You mauy be able to hide if there's tack to lay over it, but filling and sanding them is still your best bet.
    December 2008
Posted by psstoff995's lbro on Sunday, January 10, 2010 9:50 PM
I'm going to redo the horse, it didn't look as bad in real life. Tongue Tied
Here's the German
He is going to have a lot of packs on his back so I decided not to fill the gap on his legs.
    December 2003
Posted by psstoff995 on Sunday, January 10, 2010 10:34 PM
Woah!!! Looking great Will, I really like the camo uniform, good luck fixing up that horse, the flesh looks a little monotone at the moment, just try and get a wash with a darker flesh color, don't have to paint the actual shadows, but a wash might work.
Also the good thing about oils is it gives you a lot of time to blend, so if you get some light flesh and some dark flesh, paint the basecoat on then paint the darker color and while they're both wet- get a second (or third?) brush with no paint, no thinner, just clean- and then use it to blend the two gradually.
-Chris
US Army Infantryman
    December 2008
Posted by psstoff995's lbro on Sunday, January 10, 2010 10:52 PM
I redid him in acrylic because I smudged the oil (didn't know it took more than 8 hours under a heat lamp to dry Tongue Tied)
So I wiped the oil of the horse too of course.
    December 2003
Posted by psstoff995 on Monday, January 11, 2010 10:50 AM
Oh I see, well, if you wiped the horse clean then yeah, make sure you fill those gaps on him! The guys packs should be fine.
-Chris
US Army Infantryman
    March 2008
Posted by EasyMike on Monday, January 11, 2010 2:35 PM
psstoff995's lbro
http://i468.photobucket.com/albums/rr43/b0n3s4w93/Willscamera030-1.jpg
Close up his eyes a little.
Smile
    February 2008
Posted by rig medic on Sunday, January 17, 2010 5:06 AM
The horse is too much on the red side. Try giving it a little more brown. I would recommend tamiya XF-10. Do highlights and lowlights on the horse as you would with clothing. Then make higher highlights on the high points such as those on the rear hump and leg muscles. You can also accent by putting a white stripe on the front of the head and/or on the lower part of the feet near the hooves.
The figure is great. You did good on the camo. However, as of your latest post, the face needs more depths and highlights. Make good on the eyes. Put a stripe of black where the eyelashes should be. And after everything is dry, put a dab of clear gloss over the eye to give it a little shine. If you can, you could also put a small white dot in the middle of the black of the eyes to represent reflected light. Be careful, though. Don't make the dot too big.
Don't push yourself too much, man. Just have fun and do what you can and before you know it, each of your figures will be better than the previous one. Figures are fun and challenging to make. Plus, remember that you are building a replica of something that is alive. That's the big challenge in figure modelling. Have fun.
    December 2003
Posted by psstoff995 on Sunday, January 17, 2010 7:22 PM
I agree with the horse tips, and while I agree that the face needs more depth, I'd stay clear of adding more detail to the eyes, in fact I'd take some away.
At 1/35 scale you don't want the "whites" of the eyes to be white, but the same color as your flesh highlights. And while you need eyelashes, clear gloss on those tiny eyes is not going to be easy to control or to look right. At 20-30' (1/35 scale) away, if you see eyes, you don't see a shine. The eyes should look like black dots or slits, and not round dots, because you're not painting the black circle of the eyes, but ovular dots because you're also painting the colored part of the eye, and if you look into a mirror (without going all wide eyed crazy haha) you will only see about 2/3rds of your actual dot. So it's like a dot with the top and bottom painted over- look at that dio book by Shep- theres a great section of face painting where he does the dots as lines, then paints the flesh over top them to cut them down to slits.
Other than that- I agree, no need to go overboard. It's looking great Will
-Chris
US Army Infantryman
Posted by Model Maniac on Monday, January 25, 2010 5:45 AM
The painting looks OK but the soldier figure looks terrible. Look at those slim legs, the guy had probably got malnutrition or polio - or both. What a pity!
Impressive Songs:
All 10 Playlists that I created on Youtube:
http://www.youtube.com/user/ModelManiacThailand/playlists
Pan Flute Music (300 songs) (Most Popular, over 100K views):
https://www.youtube.com/playlist?list=PLUNb2zPxGTZO7alagEPsEMzgBkWt4-vKV
El Condor Pasa (Top 50) (World's most famous and my most favorite song):
http://www.youtube.com/playlist?list=PLUNb2zPxGTZOLKHbju350mLle4HkMhsb8
    June 2008
Posted by Hans von Hammer on Monday, February 1, 2010 7:34 AM
Regarding eyes... Soldiers are usually outside and squint a lot...
The legs look that way because they're molded to fit the saddle...
