GEEZE![:0]
Making a full belt would be like building a whole kit.
I guess this will make you ask the question, how much detail do I really want?
And here I thought I was nuts using a dremel, file and brass wire and turning casing tapers 2 at a time. I have taken and trimmed wire and glued the little pieces side by side onto a strip of tape or foil. From a standoff distance (someone looking at it standing up, while it was on a shelf or table) that looks fine. It won't hold up to really close scrutiny but it has an "assimilated" effect.
I suppose you could use the kits above for short sections, say....from an attached ammo can to the breech. But for anything more there is a frustration and tedium factor that at least in my case far outweighs the impressiveness of this detail. I give a hardy handshake and a "Job well done" to the guy that makes a scale "9 yards" of this stuff.
"Imagination is the dye that colors our lives"
Marcus Aurellius
A good friend will come and bail you out of jail...but, a true friend will be sitting next to you saying, "Damn...that was fun!"
