- Member since
October 2003
Posted by link955
on Saturday, January 10, 2004 1:36 AM
Absolutely, you can use it! However, keep in mind most oil colors are translucent, meaning they will show what's under them if they're applied in thin coats. If you apply them thickly enough to cover, you hide detail. Using tube oil color is a little like painting with melted butter. So here's the trick I use, and it seems to work well: I prime what I am going to paint with acrylic color, in the same or nearly the same shade as I plan to paint with the oil color. This allows you to apply the oil in a very thin layer, and not hide details. Apply a layer of your oil color first, then add highlights and blend. Next apply your shadow colors and blend. You don't have to rush; oil colors will stay wet and workable for a very long time, often days, depending on how humid your house is. Patience is the key; once you have mastered your technique speed will come. And PRACTICE. Also, you might get a copy of Shepard Paine's "How to Build Dioramas." He has a very informative section in there about figure painting with oil color, along with mixing and blending guides. Hope this helps.
Ne cede malis (Latin: Yield not to misfortune)
