Posing Figures
Posing Figures
Posted by Anonymous on Friday, January 30, 2004 4:19 PM
What's the method for posing figures? I've been learning through trial and error, but what IS the technique? I have a motor tool, razor saw, etc. Do I have to use alighter every time I want to bend an arm???
Posted by Buddho on Friday, January 30, 2004 6:18 PM
I use a fine tooth Exacto saw, and stanley Razor blades (utility knife) to cut up figures and repose them. I have bought at least 2 dozen figure kits from DML , Italeri, and Tamiya...from these kits I will build figures too. I also buy accessory kits which are full of helmets, weapons and tools. Putty is used to fill joints and voids, and paper glued with Testors regular tube model cement is used to make collars, pockets, belts and straps. I haven't used heat to rebend parts, but I am sure that will work fine too.
I found a closeup of 2 figures on an M113 Fitter. The pockets, collars, and straps for the vests are paper. I added and shaped plastic to make the Israelian tanker helmets.
Regards, Dan
Posted by Anonymous on Friday, January 30, 2004 7:13 PM
If you really want to be able to position your figures exactly the way you want them, there is a sure-fire method that is a bit more refined than melting with a lighter. A regular X-acto saw works fine, but for really delicate cuts or operating in tight places, get a jewler's saw. (X-acto makes these too). Jewler's saws can go places no other saw can, since the blade is only .02 inches wide and .010 inches thick, just the tool you need for lopping of heads, arms and legs, without messing up the rest of the figure. Saw off the offending arm, leg, hand or head. Take a pin-vise with a #75 drill bit (.021inch) and drill a 1/8 inch deep hole in both pieces of the cut. Insert a piece of .020 brass rod, (available at any LHS) glue with CA and cut the rod to just slightly more than 1/8th inch. Bend the rod with pliers to approximately the desired angle. Put a drop of CA on the other half and push onto the protruding rod. Position the arm, leg, hand or head by rotating or bending the brass rod into the desired position. Fill the gap with putty or gap-filling CA. Use a "Mouse Tail" file to file the seam smooth and paint. This technique will allow you to position arms, legs and heads to virtually any position you want. It may sound like a lot of work, but this is how the pros do it.
P.S.: For really tight spots, break off a short piece of jewler's saw blade and put it in your pin-vise, with the teeth pointing towards the handle, (not more than 1/2 inch long though, the tiny blades break easily). This will give you the smallest saw in the modeling world, great for cutting in places nothing else will fit. But be gentle, cut only on the pull stroke, they will break!
Posted by Buddho on Friday, January 30, 2004 11:20 PM
Thanks, Leopold!
I'm going to try the brass rod next time I alter figures...
Regards, Dan
Posted by Anonymous on Friday, January 30, 2004 11:27 PM
I use paperclip wire instead of the brassrod and it works just as well. Copper wire also works.
Posted by ajlafleche on Saturday, January 31, 2004 2:50 PM
Leopold's is THE method to do this. Remember when redoing knees and elbows to cut wedges or you'll wind up with disproportionate arms and legs. DON'T use a lighter, you'll ruin the figure and if you move on to resin and metal, you'll nee to learn LEopold's method anyway. And as Tappie implied, any maleable wire wil do.
You also need to consider the position you're aiming for is going to have to look natural, so the wire will help a lot here, too.
Posted by Anonymous on Saturday, January 31, 2004 5:56 PM
Wedges... I forgot the darn wedges! Thanks Ajlafleche for filling in for my momentary lapse of consciousness.
