Looking for ways to display built up figures as they get built ?
    June 2008
Posted by patton45 on Wednesday, December 14, 2011 11:17 AM
I have lots and lots and lots of built 1/35 figures that are not painted. Now I just have them in groups layed flat between kits on the shelves.
If  they never get painted I would at least like to have them upright so they could be seen.
thought about just a drop of CA glue on their feet and glue them to strips of evergreen plastic? and I could mark on the plastic the name of the set so I can match it up with the box art and extra pieces that were saved but not attached yet.  So many diorama ideas, so little time.
  I priced that stuff and it sure is expensive.  Ideas for a cheaper medium that I could use to get these guys standing up?
thx - Craig
    September 2006
Posted by the Baron on Wednesday, December 14, 2011 12:07 PM
patton45
thx - Craig
How about using white glue, instead?
How do you hold your figures, while you paint them?  For some of mine, I drill a small hole in a foot or somewhere else on the figure, and use a toothpick, sometimes with a drop of white glue.  I have some holders made out of paint can caps, with holes drilled in them.  This works well for my plastic and resin figures in 1/35 / 1/32 or 1/48, because they're relatively lighter.
If you use a holder like this, you could put a piece of masking tap on the stick and make a note on it.
Regarding your method, I'd worry that in removing them from the strip, would damage the existing paint job, if I had used CA glue.  Either you use force and snap the join, which could take paint away with it, or you use a solvent that dissolves CA--acetone is the one that I use to clean up CA--which could damage the figure.  White glue would dissolve with warm (not so hot that it scalds) water, and be less likely to damage any paint.
    April 2006
Posted by jgeratic on Wednesday, December 14, 2011 12:12 PM
I think you answered your own question about your grey army display.  Gluing them to scrap sprues that you would throw out anyways is a savings.  Maybe white glue is cheaper by the drop so if you eat a lot of popsicles you can glue them onto the leftover sticks or cut out square bases from cereal boxes?
regards,
Jack
