How to weather white winter uniforms?
    July 2008
Posted by castelnuovo on Friday, February 17, 2012 2:16 AM
Gentlemen,
I have 4 german AA gun dudes who wear white winter uniforms, the kind that can be reversed. They men an AA gun mounted on a 8t truck, so they don't crowl in a mud, but the uniforms, painted simply white, look too new, too clean, just not real at all. Can somebody suggest some simple way to dirty them up? Maybe some wash or something like that?
Thanks...
 Cheers Toast
    April 2009
Posted by deafpanzer on Friday, February 17, 2012 10:22 AM
If it was me, I would avoid using "white" on the winter uniforms to start with.  Start with darker white paint like off-white or ivory as a base coat.  Then apply darker white or even very light tone of sand paint inside the folds to break up the monotone look.  Finally use real white paint for highlighting on the edges. Keep in mind paint have to be thinned well after the base coat.
I would use heavily thinned raw umber oil paint (90/10) at the end.
Andy
    July 2006
Posted by telsono on Friday, February 17, 2012 12:24 PM
I would also suggest using a light colored oil paint like Naples Yellow as a wash alongside the raw or burnt umber to give ivory tones.
Mike T.
Beware the hobby that eats.  - Ben Franklin
Do not fear mistakes. You will know failure. Continue to reach out. - Ben Franklin
The U.S. Constitution  doesn't guarantee happiness, only the pursuit of it. You have to catch up with it yourself. - Ben Franklin
    April 2006
Posted by jgeratic on Saturday, February 18, 2012 3:11 AM
I agree with what has already been suggested, start with some kind of mixture for an off white.   With an airbrush, prime the whole figure with this.  Mix a second shade that is halfway between this and white, and spray from a top direction down to about 90 degrees - this will represent your mid tones while the first layer will be shadows.  Then from directly on top, spray white as this represents highlights.
Now you can go in with a fine brush to add more contrast to shadows.  Personally I avoid washes in terms of slathering the whole figure and hoping gravity does it thing. Precise pin washes are fine though for areas such as waist belts or buttons  for example.
As far as dirt goes, no they definitely don't roll around on the ground like infantry, but I think you'd still find some dirt on them.  If one stepped in a puddle some mud would splash upwards.  Walking around their transport vehicle could also transfer some dirt.  I'm also sure their flak gun wasn't in pristine museum condition, so to some lesser degree dirt/grease from this equipment.  The crew likely transfers mud from their boots to the gun platform, and it is possible someone knelt on one knee in that mess.
As always, the old adage less is more is a good rule to follow.
I posted this pic as it shows a good pattern of dirt on the lowers, ideal for what you are doing.
regards,
Jack
