Godzilla Vinyl Model Teeth Issue
    December 2012
Posted by G11354 on Saturday, December 29, 2012 1:45 PM
Recently purchased a vinyl Godzilla model and im debating how to deal with the teeth.  Im not sure whether to try and paint them as is, or remove the vinyl from between the teeth?
I'd like to remove the plastic but im not certain how to go about it, any suggestions would be greatly appreciated as im entirely new to this.
    March 2008
Posted by EasyMike on Thursday, January 3, 2013 9:07 AM
How about a pic of what you're talking about?  My guess is flash between the teeth.  You can trim vinyl with a hobby knife and a new, sharp blade.
Smile
    April 2009
Posted by Cadet Chuck on Thursday, January 3, 2013 12:23 PM
Also, vinyl is a lot easier to trim if you heat it up with a hairdryer or soak it in hot water first.
    February 2007
Posted by mitsdude on Friday, January 4, 2013 3:15 AM
Definitely heat the vinyl in some way. Trying to use a hobby (Xacto) knife on room temp vinyl models can result in part of you being removed.
Having said that you also have to be careful with heated vinyl as it can be cut like a hot knife through butter.
    April 2009
Posted by Cadet Chuck on Friday, January 4, 2013 1:37 PM
Mitsdude is correct.  Vinyl is very difficult to work with, and not for beginners.  I make these two AMT vintage Star Trek figures and it was a real pain, as nothing fit right.  I had to use tons of putty to fill huge gaps in the body joints, essentially resculpting the figures.  But they came out OK.
