airbrushing clogging with acrylics
Posted by Anonymous on Sunday, March 16, 2003 7:33 PM
airbrush(s): paashe model H & Iwata hp-b
paint medium(s): 1. fw acrylic ink, 2. liquitex concentrated medium viscosity paint thinned with airbrush medium and
3. water color
I create my own figures, cast them out of a hard urethane and paint them with acrylics. I have been having a problem when I detail with my airbrush in order to get fine lines. I get fine results when I use straight acylic ink or watercolor. But when I mix the liquitex with the airbrush medium I get constant clogging. I use more than enough airbrush medium. Does anyone have any suggestions or can point out what I'm doing wrong the liquitex paint. Thanks
paul
    January 2003
Posted by Keyworth on Thursday, March 20, 2003 10:36 PM
Try thinning with isopropryl alcohol instead (rubbing alcohol). Your results should be much better. Add just enough to thin your acrylics to milk consistency. Hope this helps. - Ed
"There's no problem that can't be solved with a suitable application of high explosives"
Posted by ponch on Monday, April 21, 2003 12:04 AM
I doesn't hurt either to have a q-tip moistened with isopropyl alcohol at hand, and dab at your airbrush tip when it starts getting sticky. 9 out of 10 times that'll do the trick.
