QUOTE: Originally posted by caseyn5
LOL, yeah I was hoping for an easy answer, but I guess if this hobby was easy, it just wouldnt be cool.
Toy Biz Thor haven't build that one, most of their kits got trashed badly over here and are pretty much no longer available.
Be prepared for fitting problems (lots of clamps and rubber bands will help) and get a tube or 3 of putty for the kit. You will also need a WHITE primer to make the colours look good.
Also check the parts careful I had 3 of their Kits and all had missing or wrong parts, slightly worse than Polar Lights in quality control.
IME, most plastic figure kits may they be Aurora, Polar Lights, Toy Biz, etc have a list of problem areas, more than your average resin or Vinyl kit.
As was mentioned dry-fit the sub-assemblies and see what you can paint prior to assembly and what should be painted after.
Pose on the Thor(checked it on the Net) looks vary straightforward and I reckon you can assemble him in whole prior to painting.
BIG thing with Figure kits of any medium is surface preparation, seen too many kits that just feel wrong.
Here is a tip:
When you paint the Kit, at times hold it up to a mirror and check the reflection this way you can spot a lot of problems that are hard to see looking at the kit itself.
Strange but true.
Take care and work slowly, good masking skills are a must of the large scale figure modeler.
[edit]
Kit Review: http://www.modelman5.com/tbthorpics.htm
[/edit]
