1/35 Modern US Army Multicam
    June 2003
Posted by allan on Monday, May 4, 2015 12:28 AM
Here are pics of a few of my recently built US Army figures.  Hoping to get as close as I could to the Multicam pattern.  Flesh painted using Vallejo, uniforms and gear painted with Tamiya enamels.  Comments most welcome.
No bucks, no Buck Rogers
    July 2004
Posted by stikpusher on Monday, May 4, 2015 4:29 PM
They look great! Although I might suggest a different rifle sling set up. Most guys use a 3 point type sling set up nowadays instead of the old GI basic sling.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    June 2003
Posted by allan on Monday, May 4, 2015 6:29 PM
Thanks for the kind words.
    December 2003
Posted by psstoff995 on Friday, May 22, 2015 12:58 PM
I think you nailed the Multicam pattern, both in terms of the colors that you used and the size of the pattern for the scale. Those figures look great too, who makes them?
The only thing I would do would be to make them a lot dustier, just some sand colored pigments should be fine. The dust and sun wear out the uniforms pretty quick and the pattern will turn almost monotone in places like the knees, seat, elbows, the gear especially will be very dusty, almost looking shades lighter all around just because at least the pants and tops are washed, whereas the plate carrier and pouches are usually not. One thing to note though, sometimes when guys wear the combat T shirts out on patrol, they will look a lot brighter/newer than the pants, just because they wear the pants all the time, but have to wear their thicker zip up tops day to day if they're on a large FOB. So the combat shirts might get worn a far fewer times a week depending on the tempo of operations. I wouldn't worry about the combat T shirt differences in 1/35 scale- but I do still think the guys should look a lot dustier. Even if you just did a light overspray with some sand colors out of an airbrush to tie them all together I think you'd be fine.
I will say I think the slings are fine the way you have them. While plenty of people do use the 3 point sling, most Infantryman and soldiers that have to operate their rifles complain a lot about 3 point designs. They rarely work as they are intended to and often hamper operation of the bolt release and can get tangled on gear much easier. Usually, you will see a lot of one point slings or what are often referred to as 'wolf-tails' -simply a few inches of nylon webbing and a plastic clip that attach to the weapon at the but stock or near the charging handle around the buffer tube and then loop through a D-ring or MOLLY webbing on the shoulder of the plate carrier.
Designed strictly as a retention system though, doesn't take any of the weight off of the soldier's arms like a sling would so they have to basically hand carry the weapon, but way more maneuverable and hardly gets caught up on anything. That's why its usually used for mounted operations or CQB environments where the soldier is basically dismounting, clearing a compound, then mounting back up. For a foot patrol you'd probably have the 2 point sling as you've done. Even a full sized sling set up in a one point mount doesn't wind up working well over a long period of time because they're generally worn too loose to really take up a lot of the weight of the weapon system, they tend to just let the weapon dangle and bounce off of knees when the soldier isn't holding on to it. But again, works great for a short amount of time.
www.brigadeqm.com/.../bmd05.htm here's an example of the wolf tail/wolf hook one point.
And an older version of a two point/one point adjustable sling from Magpul www.midwayusa.com/.../magpul-ms2-multi-mission-single-point-2-point-sling-nylon <- if you click on the tan/FDE color option you can see the back plate mounting option some guys use for their one and two point slings.
-Chris
US Army Infantryman
    June 2003
Posted by allan on Monday, June 1, 2015 1:01 AM
Chris,
Thank you for the compliment.
Your inputs are much valued, and I will certainly take them all into account for my future builds (and Ive got a number lined up).
The figures are all Trumpeter Modern US Army Armored Crewman & Infantry, but with rather heavy modifications on almost everything, using Apoxie clay and Tamiya Pla Paper. Even the helmets were re-sculpted to make them appear similar to the real thing.
On a related note, have you seen Airborne troops in jump gear wearing Multicam/Scorpion camo yet?  Id love to be able to model that.
Posted by HeavyArty on Monday, June 1, 2015 4:37 PM
Looking pretty good.
    July 2004
Posted by stikpusher on Saturday, June 13, 2015 4:09 AM
allan
I just came across this clip on youtube. Presumably 3rd Batt. In the new multicam
With the Ospreys at the end, I had a serious mental image of Heinlein's retrieval boats from Starship Troopers.
       - Plankton
LSM
    June 2003
Posted by allan on Sunday, June 14, 2015 8:41 AM
Stik,
Exactly what I'm looking for! Many thanks for that.
    December 2003
Posted by psstoff995 on Sunday, June 14, 2015 1:24 PM
Wow!! Thanks for the in progress shot, some amazing scratch work
-Chris
US Army Infantryman
    November 2015
Posted by Chris1985 on Saturday, November 14, 2015 3:41 AM
Hi could you tell me wait colours you used for the cam and your technique thanks
Posted by Gamera on Sunday, November 15, 2015 8:16 PM
Wow, they came out great! Love the extra work you put in there.
    June 2003
Posted by allan on Sunday, November 15, 2015 9:01 PM
Gamera,
Thanks so much for the kind words!
Chris,
I use Tamiya enamel colors for the uniforms. The exact mixes are as follows:
1. XF-57 Buff
2. XF-60 Dark Yellow
3. XF-60 (85%) + XF-64 Red Brown (15%)
4. XF-5 Flat Green (30%) + XF-49 Khaki (70%)
5.  XF-1 Flat Black (70%) + XF-57 (30%)
    January 2011
Posted by Tal Afar Dave on Tuesday, April 26, 2016 8:01 PM
As Chris mentioned earlier, the 3-point slings were a double edged sword.  If you were running mobile patrols from humvees, it got difficult to use the the 3-pt. slings because they kept getting hung up in vehicle equipment such as radios, stowed gear, and seat belts.  Driving around in a wheeled vehicle makes you a target, so you want to unass the vehicle as quickly as possible and without entanglements.  Our solution was to take a D-ring, parachute cord (also known as 550 cord or para cord) and 100 mph tape (OD green duct tape, fixes everything!! Smile)  We would make a double loop of 550 cord and run it thru the sling attachment points on the M4s.  The loops would be about 8" in length. We then wrapped 100 mph tape tightly around the para cord loops so that they became harder to tangle with gear and pouches on IBA.  The loop would then be passed through the D-ring and fastened to the shoulder loop at the top of the IBA.  When you needed the rifle, it was right there on your firing shoulder.  When you needed your hands to operate a radio, or pull concertina wire, the rifle would dangle along your body, out of the way.  I still have my D-ring and para cord "ghetto sling."  It cost about $6 compared to the $25 and up 3-pt. slings......gotta love GI ingenuity!!
TAD
2022 New Year's Resolution:  Enter 1 group build and COMPLETE a build this year!!  Why Photobucket did you rob me of my one Group Build Badge???  Must be part of the strong anti-Monogram cartel!!!
    January 2011
Posted by Tal Afar Dave on Tuesday, April 26, 2016 8:08 PM
BTW Allan, tremendous job on getting the camo right and putting in the additional scratch work.  It really brought out the versitility of the MOLLE system.  Outstanding all the way around!!
Dave
    July 2004
Posted by stikpusher on Wednesday, April 27, 2016 3:06 AM
Tal Afar Dave
Dave
Ditto
       - Plankton
LSM
    June 2003
Posted by allan on Wednesday, April 27, 2016 8:47 AM
Thanks again for the kind words, Dave and Stik!
Dave,
I'd really like to see that D-ring set up you have. Tips given by actual fight men are probably the best we modelers can get. :)
    March 2013
Posted by MikeyBugs95 on Sunday, July 10, 2016 11:03 PM
Wow! This is incredible! I love doing modern US figures (even though I can't to save my life but always helps to practice) because there's so many possibilities to them. Have you seen the products by Live Resin? Some of his stuff is also really good like this (no affiliation).
On another note, is the PEQ-2 TPIAL still in use or has the Army/Marines switched to PEQ-15 ATPIAL wholly?
 In progress:
CAD:
1/35 SINCGARS ICOM/ASIP; 1/35 Flat screen TVs; 1/35 tactical light that I shall reveal later Devil
Models:
1/35 DML M4A1 DV; AFV Club M18 Hellcat; DML StuG IV; DML Armored Jeep w/ .50 cal; Panda Cougar 4x4 MRAP; Academy M3A1 Stuart; 1/700 Midship Models USS Miami; 1/700 Skywave Rudderow Destroyer Escort
    January 2011
Posted by Tal Afar Dave on Wednesday, September 14, 2016 9:38 PM
I'll see if I can dig up a picture or two and post it, if you are interested.
TAD
    November 2015
Posted by OldJimbo on Tuesday, December 17, 2019 12:23 PM
allan
allan
 I'm coming late to doing modern US Army.  Thanks for the great pictures and paint list.  The Tamiya Army and Marine set just lists buff, dark gray, and a combo of the two. Liked your colors better.  Are yours from the most recent 2018 - 2019 uniforms or some previous year?  Checked the Army internet and colors didn't look as good as yours.
Posted by CapnMac82 on Sunday, December 22, 2019 9:05 PM
Well, dang, I'm sorry I missed this before PB shut the photos down.
UCP is a funky pattern in full size, and the LBE covers so much as to make modeling that gear would be complicated.
    July 2004
Posted by stikpusher on Sunday, December 22, 2019 9:27 PM
CapnMac82
       - Plankton
LSM
    April 2019
Posted by John 3:16 KJV on Monday, December 23, 2019 2:45 PM
stikpusher
CapnMac82
Hehehe... Yes
     “For God so loved the world, that he gave his only begotten Son, that whosoever believeth in him should not perish, but have everlasting life.
     For God sent not his Son into the world to condemn the world; but that the world through him might be saved.”  - John 3:16-17
