ESCI figures, how are they
    June 2006
Posted by Tankluver on Tuesday, January 26, 2016 10:05 AM
How are ESCI 1/35 figures, I saw a bunch on ebay, and I saw a few of there vehicle kits and am tempted to buy one, how is the quality of the plastic, is it detailed or is it going to be like getting army men.
    October 2009
Posted by Gear Head 6 on Tuesday, January 26, 2016 10:24 AM
ESCI did make some good hard plastic figure sets in the early eighties.  They later went to soft plastic with all the soft plastic problems.  Paint coming off while the figures were being put in place or just falling off over time in a diorama.
Posted by Gamera on Tuesday, January 26, 2016 11:05 AM
Well, their vehicle kits go from good down to so-so.
I have some of their figures that Gear Head 6 refers to and I wasn't all that impressed even back then. I'd say they resemble Frankenstein's monster more than your average human- blocky, slightly out of proportion, and stiff. You might try replacing the heads with better aftermarket ones but still it seems to me like putting lipstick on a pig.
You're better off with Masterbox, MiniArt, Dragon, or even the newer Tamiya ones. If you can get them cheap enough they might be useful for donor arms and other parts though.
    June 2006
Posted by Tankluver on Tuesday, January 26, 2016 3:19 PM
Ok, I was looking for cold war soviet figures shooting rpgs and the only kit ive seen so far is esci, I'm doing a two part dio!
Posted by Gamera on Tuesday, January 26, 2016 6:36 PM
Well, if it's the only figure you can find it might be worth a shot.
I looked around Ebay and found a couple of sets of Soviet Cold War figures.
Two from Dragon:
http://www.ebay.com/itm/Dragon-1-35-Elite-Force-Military-Figures-Soviet-Spetsnaz-New-Shrinkwrapped-/281916075734?hash=item41a381eed6:g:lt4AAOSwqu9VLQrC
http://www.ebay.com/itm/DRAGON-MODELS-1-35-SCALE-SOVIET-VDV-AIR-ASSAULT-FORCE-PLASTIC-MODEL-FIGURES-KIT-/110607835340?hash=item19c0bda0cc:g:usUAAOSwI-BWFqVE
I have the top set from ICM, and it's some nice figures, I dunno about the others:
http://www.ebay.com/itm/ICM-1-35-SOVIET-TANK-CREW-FIGURES-MODEL-KIT-35601-/120574274582?hash=item1c12c96c16:m:mlUdhkRAFC8pIipaRRZjHMA
http://www.ebay.com/itm/Afganistan-1979-1988-Soviet-Forces-8-figures-1-35-ICM-35004-RARE-/291665926730?hash=item43e8a4da4a:g:oRAAAOSw9mFWKhnf
http://www.ebay.com/itm/ICM-1-35-Soviet-Afhgan-War-1979-1988-Sappers-figure-Set-Cold-War-/172074155819?hash=item28106b3f2b:g:wQ0AAOSw6EhUPZgw
http://www.ebay.com/itm/ICM-1-35-Soviet-Afhgan-War-1979-1988-Special-Troops-figure-Set-Cold-War-/182000923968?hash=item2a6019b540:g:0K8AAOSwY45UPZhC
http://www.ebay.com/itm/ICM-1-35-Soviet-Afghan-War-Motorized-Infantry-1979-1988-4-figures-35331-/311486772582?hash=item48860ef566:g:N54AAOSw14xWPk58
http://www.ebay.com/itm/ICM-1-35-Soviet-Afghan-War-1979-88-Soviet-Tank-crew-Plastic-Figure-Kit-35281-/141784077450?hash=item2102fd548a:g:F-EAAOSwEetWBIhG
I've got a few sets of Zvesda's 1/48th figures which are great, not sure about their 1/35th:
http://www.ebay.com/itm/Zvezda-1-35-Soviet-Paratroopers-Afghanistan-figure-Set-Cold-War-/182000935218?hash=item2a6019e132:g:9E4AAOSwU9xUPZhe
http://www.ebay.com/itm/Zvezda-1-35-3619-Soviet-Paratroopers-Afghanistan-Figure-Soldier-Free-Shipping-/251856830215?hash=item3aa3d63f07:g:1aIAAOSwPYZU7sfK
In any case I expect any of them will probably be better than the ECSI figures.
    June 2006
Posted by Tankluver on Tuesday, January 26, 2016 7:37 PM
Gamera
Two from Dragon:
Thanks, these help alot acutully, I wanted to also do a diorama of the armoured assault into Grozni in the first chechen war, but im going to use resin kits for that. I like the ICM tank riders from afghanistan for that and another  Diorama I had an idea for. Was the the tropical hat common for many soviet units or just airborne, and was that only cause they were in Afghanistan?
Posted by Gamera on Tuesday, January 26, 2016 7:54 PM
No problem at all, I didn't know about a couple of those sets and might have to pick up one or two for myself.
I dunno about the hats, Stikpusher might know but I have no idea. Embarrassed It would probably be easy to replace with a spare Soviet helmet.
    June 2006
Posted by Tankluver on Wednesday, January 27, 2016 9:14 AM
Gamera
Yeah I'll probably take a look around and see what others say and do more research, but first I want to get my part one of my red dawn themed diorama rolling before I start anything else, or at least have all the kits put together before I start getting side tracked.
    July 2004
Posted by stikpusher on Wednesday, January 27, 2016 12:02 PM
The ESCI figures are no better than toy soldiers/green army men. Nothing that you would want in any diorama. Dragon, Zvezda, and ICM all make Cold War/Afghan War Soviet figures that will be far better for your purposes.
As far as Soviet headgear goes, like any other military, it depends upon the climate, mission, and situation. Soviet paras wear a gream cloth padded helmet for jumps, nearly identical in appearance to the tankers helmet, but with some detail differences. Otherwise they can wear steel helmets, boonie hats, soft caps, or the classic Ushanka. As well as their distinctive blue berets. Boonie hats were seen most in the hot weather and climates of southwest asia. soft caps in warm weather months of more temperate climates, Ushankas are worn in cold weather in nearly all areas, and steel pots or jump helmets as the situation requires. Berets tend to be worn more for garrison or parade wear.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    June 2006
Posted by Tankluver on Wednesday, January 27, 2016 7:03 PM
stikpusher
Thanks Stikpusher, I always thought the Russian hats of looked like the bucket hats that the SF wear at times. The ESCI figures I saw looked a little toy soldierish so I no goed that plan.
    July 2004
Posted by stikpusher on Wednesday, January 27, 2016 7:39 PM
SF bucket hats? You lost me on that...
       - Plankton
LSM
    June 2006
Posted by Tankluver on Wednesday, January 27, 2016 8:17 PM
They call them bucket hats now, or the kids do at least, but instead of helmets, didnt they used to have a cover it looked like this
https://www.google.com/search?q=army+bucket+hat&biw=1600&bih=799&tbm=isch&imgil=B2-9_sWy7HqSWM%253A%253BO84g31fwRusLCM%253Bhttp%25253A%25252F%25252Fwww.ebay.com%25252Fbhp%25252Farmy-bucket-hat&source=iu&pf=m&fir=B2-9_sWy7HqSWM%253A%252CO84g31fwRusLCM%252C_&usg=__xF1Q0eGiaPBh6ATcGRxwkHxC_qI%3D&ved=0ahUKEwi2-5fNuMvKAhUE1CYKHbNbBB0QyjcIRg&ei=g3qpVvatEoSomwGzt5HoAQ#imgrc=B2-9_sWy7HqSWM%3A
    July 2004
Posted by stikpusher on Wednesday, January 27, 2016 8:30 PM
We called 'em boonie hats. Had them issued to us in SF and in LRS. Although they are standard issue to hot weather deployments as well for pretty much all types of units. They have an official name too. Something like "Hat, Hot Weather, Camoflage" or "Hat Sun, Camoflage"... in Army Jargon.
Most every piece of headgear worn by SF is used Armywide with the exception of some helmets.
       - Plankton
LSM
    June 2006
Posted by Tankluver on Wednesday, January 27, 2016 9:02 PM
stikpusher
I just remember always seeing the old army of one commercials with the guys manuevering through a swamp wearing them.
P.S. Are ESCI model tanks any good to build? Or is it still toyish
    June 2003
Posted by allan on Tuesday, February 2, 2016 2:33 AM
If these are the soft plastic variety, then Stik is right.  Theyre basically toys. The 1/72 are better only in the sense that they are detailed for their size.
But apart from the toy-like appearance youre going to have to contend with paint chipping as its hard to make them adhere to soft plastic.
No bucks, no Buck Rogers
Posted by HeavyArty on Tuesday, February 2, 2016 8:37 AM
Tankluver
Don't get me started on that stupid "Army of One" ad campaign.  No one in the military at the time liked it.  You are never an Army of One.  The lone guy running across the desert was absurd.  We always have at least a battle buddy and usually a team of at least 4 whenever we do anything.  It was a stupid ad campaign and I'm glad it is gone.  I thought the "Army Strong" one was good and the current "Join the Only Team That Makes a Difference... " one is pretty good.
Tankluver
Most Esci kits are pretty bad with '70s mold technology.  Many of them were good at the time they came out, but have been eclipsed by newer kits.  The one exception is their M60 tank kits.  Until the recent AFV Club M60A1 kit (which is excellent), they were the best M60s on the market.  They still hold up pretty well and offer types that AFV Club does not yet offer (they are supposed to come out w/the whole M60 line, eventually).
Posted by Gamera on Tuesday, February 2, 2016 10:16 AM
Thanks Gino. I remember the Esci kits being pretty gosh awful but someone (maybe you) mentioned the M60 kits being good so I picked one up for twenty bucks and have been doing some work on it and am pleasantly surprised.
    July 2004
Posted by stikpusher on Tuesday, February 2, 2016 1:43 PM
Gear Head 6
Actually ESCI's styrene plastic figures date back to the mid 70s or so. They even teamed up with Aurora back then in co marked boxings. They were on par if not a tad bit better than the Tamiya figures of the same time. And with some intersting subjects not seen elsewhere at the time such as Partisans and British Paras.
       - Plankton
LSM
    June 2006
Posted by Tankluver on Wednesday, February 3, 2016 11:35 AM
So I did some looking and I found Rest models that has a nine company figure set based off of 9th company the movie.
http://www.restmodels.com/?p=model&id=22&s=1&l=en
has anyone built or used these figures or this company?
    July 2004
Posted by stikpusher on Wednesday, February 3, 2016 1:58 PM
Those look nice. I have not seen nor built them myself. One thought for your scenario, espcially after looking at those figures- location & weather. "Red Dawn" starts in the fall on the edge of the Great Plains/Rockies- cool to cold  weather. Now mind you, it's your diorama, so you can mix it up to summer, spring, in whatever location you prefer, but... Troops need to be equipped appropriately. Dont mix guys in hot weather summer uniforms with guys in cold weather winter uniforms.
       - Plankton
LSM
    June 2006
Posted by Tankluver on Wednesday, February 3, 2016 8:43 PM
Yes I realized  are in more summer apparel then they are in winter
