Turpentine: Artist's Store or Hardware Store?
Posted by djrost_2000 on Thursday, May 5, 2016 5:32 PM
Making my way to town tomorrow, and the question is should I buy Artist's turpentine to clean my brushes or is the hardware store variety good enough.  I've heard rumors that turps can make your work look yellowish.  Basically want to be using turpentine to clean brushes of enamels and artist's oils.  For figure painting I plan to use oils with mineral spirits as a thinner along with refined linseed oil to prolong working time.  If there are any flaws in my logic please let me know, I can take it!
Thanks, Dave
    March 2008
Posted by EasyMike on Tuesday, May 10, 2016 11:33 AM
I buy turpentine off the shelf at Wally World.  I'm not concerned with what the actual quality might be.
Smile
    June 2003
Posted by Mark McGovern on Friday, May 13, 2016 7:44 AM
EasyMike
Ditto.  Hardware store solvents do the same job just fine.  Using them, I've never noticed any color changes in my paints.
Mark McG. It seemed like a good idea at the time...
McGovern's Models.com
    August 2005
Posted by Phil_H on Friday, May 13, 2016 8:09 AM
Artist's turpentine comes in two broad types. One, actual turpentine, is distilled from pine resin and the other "turpentine substitute" or "mineral turpentine" is a petroleum distillate.
My understanding is that mineral turpentine and mineral spirits are essentially the same thing and may be used interchangably.
    November 2008
Posted by plasticjunkie on Friday, May 13, 2016 8:34 AM
I actually use Lacquer Thinner to clean my brushes. I notice that LT will remove more junk from a paint brush and air brush than regular thinner or turp.
 GIFMaker.org_jy_Ayj_O
    August 2009
Posted by JOE RIX on Friday, May 13, 2016 9:16 AM
plasticjunkie
I'm in the same camp as PJ in that I use lacquer thinner for all my brush cleaning when using oil based paints. I use artist's turpentine to thin artist's oil paints for some of my pin washes.
"Not only do I not know what's going on, I wouldn't know what to do about it if I did". George Carlin
    September 2009
Posted by Cobra 427 on Friday, May 13, 2016 12:03 PM
Phil_H
NOPE! There's absolutely no difference between the two. I've never heard of any such a thing! ALL turpentine is made from petroleum. These are distilled from petroleum byproducts. This is how they cut oil paints.  Laquer thinner is too hot! It eats any type of brush made from synthetic products and it eats the glue inside the ferrules - too messy! Just use hardware turpentine - it's all the same, except turpenoid which is just the denatured version.
~ Cobra Chris
Maybe a picture of a squirrel playing a harmonica will make you feel better?
    May 2003
Posted by jtilley on Friday, May 13, 2016 12:19 PM
Shepard Paine, one of the most respected military miniature sculptors and painters ever, says, in his book on the subject, that there's no practical difference between turpentine in a 1 oz. bottle bought at an art supply store, and turpentine bought by the gallon at a hardware store. He also says hardware store "paint thinner" does the same things. I'm perfectly content to believe him.
Art supply stores do sell other thinners for oil paints, differentiated mainly by how much they smell. I have a bottle of Winsor and Newton "Oderless." I don't have a good sense of smell, but to me it smells distinctly of turpentine - but nowhere near as strongly as the traditional stuff.
    November 2008
Posted by plasticjunkie on Friday, May 13, 2016 12:38 PM
jtilley
Ditto. As a matter of fact, I use LT, regular thinner and Turp from Home Depot or Lowes. I picked up a small red can of the Testor's thinner at Hobby Lobby to compare and can't tell the difference in performance between the Testors and HD thinner.
Posted by djrost_2000 on Friday, May 13, 2016 2:31 PM
Thanks for the replies.  Is it still considered safe to run lacquer thinner through an airbrush?  I do have a spray booth and good repspirator.
Dave
    November 2008
Posted by plasticjunkie on Friday, May 13, 2016 7:11 PM
djrost_2000
Dave
LT is my standard cleaning solvent to remove any type of paint from my air brushes. The only issue that can come up is if you soak the ab body in LT, then the rear seals can be damaged. If I soak the body in LT, then I only submerge the tip/ front part only, not the entire body.
Posted by djrost_2000 on Saturday, May 14, 2016 7:51 AM
Thanks plastic, I've read about how LT can eat the seals, so basically I'd just run LT through the airbrush between colors, and only soak parts that have no seals, and brush and q-tip the rest.
Thx, Dave
    September 2009
Posted by Cobra 427 on Saturday, May 14, 2016 9:36 AM
You can replace seals. However, if you don't have you shouldn't.  I soak my AIRBRUSH in mineral spirits, but I use lacquer thinner only with cotton swabs to clean with. I don't use lacquer thinner with paint brushes. As I said before it eats the paint of the brush handle, and the glue that holds the ferrules. You should only use lacquer thinner with paint equipment that doesn't have rubber, or silicone seals. Or only use on the parts that don't have any soft seals of any kind in them.
~ Cobra Chris
    November 2008
Posted by plasticjunkie on Saturday, May 14, 2016 11:25 AM
Cobra 427
I only clean and not soak the wristles of my brushes in LT, then use a paper towel to lightly dry them. Most are over 10 to 25 years old and are in near brand new condition.
Posted by djrost_2000 on Saturday, May 14, 2016 5:14 PM
Thank you Cobra, I got rid of my paint brush cleaning jars full of LT and will be using mineral spirits instead but may use LT for tough jobs.
Dave
