- Member since
Posted by CapnMac82
on Sunday, July 10, 2016 8:36 PM
All I can offer is how I've always approached layered things. Start at the bottom layer, get that paint right, and then move up.
Nifty tidbit: American issue helmet netting was very coarse, about 3"(75mm) square. The US forces preferred to use the British netting, which was much tighter, about 1" (25mm).
The British netting used a drawstring, which meant id could be better secured to the metal helmet shell of the US helmet, especially when separated from the inner liner. The American netting was meant to just be jammed between helmet and liner, so it came loose whenever the two were separated.
