Decals are likely useless, you'd need so much solvent that they'd likely dissolve.
"Scale Effect" is your friend.
At 3" away, you are a scale 8 feet away. So, you really only need to generalize the color range, and then use dots to suggest the teture.
Use google images to get some examples of how that should look.
