ok, now heres a really dumb question..
Posted by ipms40049 on Sunday, April 4, 2004 1:26 PM
.. but what are the main paints, say enamel, to paint a figure. IE: just the face and hands.
Thanks!! just ignore my stupidity here
Pat
Pat Hensley Booneville, Ms "Thank you for being here and playing nice"...please do not drag sand outside the box ! CURRENT BUILD(s) Revell 1/72 U Boat VII C Tamiya Willys Jeep - for 2010 Nats Bronco's Staghound -for 2010 Nats Dragons M16 Multi gun carriage - for the 2020 Nats. LOL
Posted by Anonymous on Sunday, April 4, 2004 1:54 PM
I'll quote my post from this topic http://www.finescale.com/fsm/community/forum/topic.asp?page=-1&TOPIC_ID=17284&REPLY_ID=159240#159240
QUOTE: Well, for Humbrols, which I use, though I do all my flesh tones with oils, try 94 German Pale Yellow as a base. You can add a touch of red, though it has to be a touch. Red is a color I call "coruptive", as in it can easily corrupt a mix if you're not careful, so a little goes a really long way. As it is, 94 is a pretty good base flesh tone though.
I still use it as my base for which to lay my oil mix onto, but before I got into oils, it was my primary flesh color. I don't know if you want to add shade and highlight (you did say that you didn't want to experiment too much), but if you do, a good red/brown will work. Try 160 German Camouflaged Red Brown, with maybe a touch of black or dark blue to kill some of the red. White to the base will work for highlights, though you may want to add a minute amount of red to pinken it a tad.
If all else fails. Red, white, yellow and black will make a passable flesh tone. Mix the white and the red first, then add the yellow to make a yellow-tan, and finally a touch of black to gray it a touch and also to kill the orange hue. Just add any of the colors you deem neccessary to adjust until it's where you want it, though too much black will screw it up and make it too gray. Shadow and highlight as I described above. Blue and/or green can kill red, as can black, so keep that in mind if your shade color seems too red.
Mess around on a card or something to see where you need to take it.
Hope that helps.
    August 2003
Posted by South Aussie on Monday, April 5, 2004 3:06 AM
Pat;
I usually use Humbrol enamels for fiqures apart from skin tones where I usually use oils. Lately I have beeing experimenting with Vallejo Acrylics including skin tones, their range of colors include a series of skin tones that with careful blending can be as good as oils.
Wayne I enjoy getting older, especially when I consider the alternative.
