Airbrushing figures
    June 2006
Airbrushing figures
Posted by Tankluver on Tuesday, March 3, 2020 3:47 PM
I had this idea about a month ago, i thought about airbrushing my figures like i would an AFV. I use the shadow method painting a kit all black then lighting with white on the most sun exposed areas. My question is would this same method work the same on figures. Painting the shadows black and painting the exposed areas white. Then finishing it off with the base color of the uniform ?
    April 2006
Posted by jgeratic on Tuesday, March 3, 2020 7:37 PM
I've not tried it exactly that way, but yes have sprayed figures with the airbrush - always spraying from the top with successive lighter colours.  In 1/35 scale you might find the final colour will fill in the shallower folds quite quickly.  Really depends on the angle you will hit the surface with.
You should try it and post the results here.
regards,
Jack
    June 2006
Posted by Tankluver on Tuesday, March 3, 2020 8:43 PM
jgeratic
I've not tried it exactly that way, but yes have sprayed figures with the airbrush - always spraying from the top with successive lighter colours.  In 1/35 scale you might find the final colour will fill in the shallower folds quite quicly.  Really depends on the angle you will hit the surface with.
regards,
Jack
I used to be able to post pictures but now i cant. i May need one of those phot sharing accounts.
I tried airbrushing fallschirmjager but it didn't look right when it was all said and done. Also have attempted some DAK figures with Scale 75 paint but only did the vase coat so far.
    April 2019
Posted by John 3:16 KJV on Tuesday, March 3, 2020 8:45 PM
For the photos, you can try PostImage. It’s free. :)
     “For God so loved the world, that he gave his only begotten Son, that whosoever believeth in him should not perish, but have everlasting life.
     For God sent not his Son into the world to condemn the world; but that the world through him might be saved.”  - John 3:16-17
    June 2006
Posted by Tankluver on Wednesday, March 4, 2020 1:16 AM
John 3:16 KJV
thank you
Posted by Gamera on Wednesday, March 4, 2020 11:53 AM
I've tried it but not had that much luck with it. I do however sometimes drybrush the figures from the top down laying lighter colours on the tops of the figure and then mix up about 50% uniform colour and 50% matte finish and spray them a few times to tone down the contrast and blend everything together afterward.
    September 2006
Posted by the Baron on Wednesday, March 4, 2020 12:46 PM
If you search on YouTube, you should be able to find videos by painters who paint a figure almost entirely using an airbrush.
I find it tricky enough to master painting them by hand, and I'm still too much of an airbrush novice, to use an airbrush to paint my figures.
I do want to try it on larger figures, though.  I have some anime figures in my stash, and one in progress, where an airbrush would be useful to lay down skin colors on large areas.  I've also got a female figure which I want to paint as wearing stockings, and the airbrush can be used to achieve that effect.
    June 2006
Posted by Tankluver on Wednesday, March 4, 2020 2:05 PM
the Baron
Yeah I've done the YouTube videos. I feel like airbrushing is only good if you can get a few figures done. For me i feel like i put to much paint or to little to make it worth it at times.
    September 2006
Posted by the Baron on Thursday, March 5, 2020 12:54 PM
Andrea Miniatures put out a book some years ago on painting female figures.  It included a chapter on using the airbrush to paint a figure that was either 90mm or 110mm.  Again, it was used as some of us have described, to paint large areas of exposed skin, and to do fine opaque layers to simulate nylons.  But the author of that article also described doing shading.  The fine details, such as the model's face, he painted by hand.  If you can find that book, it's a good reference to have.
Posted by keavdog on Thursday, March 5, 2020 1:34 PM
I recall seeing an article about shooting black on a figure oposite of the light source.  A kind of preshading for figures if you like.
Thanks,
John
    March 2007
Posted by KAYSEE88 on Saturday, March 7, 2020 2:12 AM
Tankluver
Not only does it work, its the ONLY way to do figures!!
Been doing it for years and years.  Airbrushing gives you effects you can't get with a brush.  But you should practice on some green army men until you get a feel for your particular airbrush.  I'm too lazy to put up a video tutorial on this matter Whistling, but i wish you luck
    June 2004
Posted by TigerII on Saturday, March 7, 2020 2:39 PM
I've done it on larger scale figures and they've come out very well. On 1:35 scale I like to airbrush the head but you still have to revert to hand brushing to get certain highlights. With the uniforms it is also the same thing. I get a great base coat with the airbrush, but when it come to shadow washes and highlights I feel the hand brush is still the best for painting control.
Achtung Panzer! Colonel General Heinz Guderian
Posted by keavdog on Monday, March 9, 2020 1:07 AM
The april edition of FSM Form & Figure article discusses using an airbrush to do a very nice Napoleonic figure.  It is a 200mm figure so on the larger size.
Thanks,
John
    November 2014
Posted by Nuckss on Monday, March 9, 2020 1:24 AM
Yes, the mini painters call it zenithal highlighting and masters like Vince Venturella and others swear by it.
    September 2006
Posted by the Baron on Monday, March 9, 2020 12:12 PM
KAYSEE88
Tankluver
Been doing it for years and years.  Airbrushing gives you effects you can't get with a brush....
I challenge you to paint the eyes on a 54mm figure with an airbrush.
    March 2007
Posted by KAYSEE88 on Friday, March 13, 2020 8:54 AM
the Baron
KAYSEE88
Tankluver
I have done it-------i dipped the needle tip to a drop of paint and touched it to the figure. Smart, huh?? Stick out tongue
    September 2006
Posted by the Baron on Friday, March 13, 2020 12:49 PM
KAYSEE88
the Baron
KAYSEE88
Tankluver
Doesn't count, smart guy!  The brush must be fully assembled, loaded with paint, and use the compressor.
    January 2015
Posted by M. Brindos on Sunday, March 22, 2020 4:56 AM
I airbrushed the black trousers on this figure. The mid tone was sprayed at about a 45° angle and the highlights at about 21° approximately.
Go light and go slow. It's not too hard.
- Mike Brindos "Lost Boy"
Posted by keavdog on Sunday, March 22, 2020 5:01 AM
Well done brother!
Thanks,
John
    January 2015
Posted by M. Brindos on Monday, March 23, 2020 2:37 AM
Thank you very much! Big Smile
    June 2006
Posted by Tankluver on Monday, March 23, 2020 9:22 AM
M. Brindos
This looks awesome,
