cleaning resin heads
Posted by Anonymous on Sunday, October 3, 2004 1:15 PM
Big Smile [:D] hi all has any one have any tips on cleaning resin heads i have recently purchased some heads from hornet to practice on and was wondering what would be the best method to remove casting oilsApprove [^]
Posted by renarts on Sunday, October 3, 2004 4:46 PM
A wash of some water and dish detergent, follwed with a good rinse should do fine.
Prime your resin before painting with whatever you feel comfortable painting on. Some use a light grey, some a white.
    August 2003
Posted by South Aussie on Tuesday, October 5, 2004 1:18 AM
Sign - Ditto [#ditto]Sign - Ditto [#ditto]
Once cleaned try not to touch the surface with bare hands as they can leave oils on the cleaned surface.
Wayne I enjoy getting older, especially when I consider the alternative.
Posted by Anonymous on Tuesday, October 5, 2004 4:48 AM
Prior to cleaning Resin Heads I normally skewer them on a metal rod or similar, this allows nice handling from washing, priming to painting.
You can either cut the rod off prior to gluing the head on or drill a hole in the bodies neck, shorten the rod and attach the head that way.
Posted by Anonymous on Thursday, October 7, 2004 11:57 AM
many thanks for tips
