Priming Resin
Priming Resin
Posted by Anonymous on Monday, October 11, 2004 10:30 AM
With what should I prime a resin figure? I tried Testors Model Master enamel - a flat light gray, but find that after 20 hours drying time, the paint still smells strongly of the solvent, and rubs off the figure as I handle it. Should it dry longer, or is this not a good choice of primer. I plan to paint hte figure with acrylics.
Posted by rjkplasticmod on Monday, October 11, 2004 12:06 PM
First, Welcome to the Forums Sign - Welcome [#welcome]. Resin must be completely cleaned before any primer is used to remove mold release agents. It's possible the oils on the resin contaminated the primer on your model, as it should have dried over that time period. After cleaning, I prime figures with either Citadel Acrylic primer, in White or Light Grey, from a spray can or with Floquil Grey Primer, an enamel, if using an airbrush.
Regards, Rick
Posted by Anonymous on Monday, October 11, 2004 12:59 PM
Thank you for your help. I did not wash the figure, having never dealt with resin before.
Posted by Anonymous on Monday, October 11, 2004 3:23 PM
As Rick has said first wash the part well, try to touch it as little as possible as oil from your fingers will undo your "washing" work.
For priming get a good model primer like Tamiya, Gunze or similar.
How well the primer sticks will also depends on what type of resin was used and how well the maker cleaned the part prior to packaging it.
If you want more details feel free to drop me a line.
Posted by renarts on Monday, October 11, 2004 5:42 PM
A good washing and any good automotive primer should work fine. I use Krylon, Rustoleum, Testors or any of the other common modeling primers available. THe key being one that has tight adhesion (doesn't lay on thick) and a good eye and hand to know when enough is enough. You want it to conform to detail without filling in detail.
Posted by Anonymous on Tuesday, October 19, 2004 10:52 AM
I didnt think to wash my resin figure and used Humbrol matte white to undercoat. Next figure I will wash for good measure and undercoat with the color I want to end up with since it seems like a waste of time to start with another color. I had no problems with the paint adhering and I did a lot of handling over the course of the project. I used Humbrol enamel with some oil added for shading and highlighting, since I am not a fan of acrylics.
