help with painting buttons
Posted by Anonymous on Wednesday, October 20, 2004 8:16 AM
Smile [:)] hi all does anybody know a good procedure for painting buttons on figures in any medium (oils enamels acrylics) grateful for any advice Big Smile [:D]
    September 2003
Posted by KevinCollins on Wednesday, October 20, 2004 8:47 AM
Hi,
What scale are you painting? I paint 1/35 (or any scale) with enamel or acrylic...usually with a toothpick or something similar.
Pray for Surf! Proud sailor (USNR) of IBU 21...NCW Group2
Posted by renarts on Wednesday, October 20, 2004 9:06 AM
Metalic buttons, I use metallic paint and then depending on the color of uniform a drop of wash to let capilary action surround the button and define it a bit more.
For subdued buttons, whatever the appropriate color of the button and then a wash, once again so that the button is defined with a darker color. A little drybrushing to highlight the area dependent on light direction.
I use a 10/0 liner a 3/0 and a fine round for much of my painting.
Posted by rjkplasticmod on Wednesday, October 20, 2004 9:26 AM
All good advice. I also use a high quality ( read expensive ) special 10/0 liner brush for small details like buttons. The medium makes little difference, but I would usually use Humbrol enamel or Vallejo acrylic for small details, even if the most of the figure were done in oils.
Regards, Rick
Posted by Anonymous on Sunday, October 31, 2004 8:43 PM
Another tip for you guys: paint the buttons first with the color you want, then paint around them. It is easier than trying to paint a button when the surrounding area has been painted. If you paint the details with acrylics and let it dry and then paint the rest with oils, the oils can be washed off the buttons with a little thinner as well. I do this with a lot of fiddly little details, even on tanks.
Just another idea.
