Assembly
Assembly
Posted by Anonymous on Monday, January 17, 2005 9:47 PM
When painting 1/35 figures, should I assemble them before painting, or paint them while still on the sprue? I should probably put on a a base coat before assembly right? Any help is appreciated.
Posted by HeavyArty on Monday, January 17, 2005 10:03 PM
I usually assemble the basic figure first, then add detail items and heads after. For example, I assemble the legs and torso and paint them, also paint arms separately and all gear separately. I attach gear with superglue, then attach head with helmet etc. Lastly, I attach arms with super glue in the proper position to hold the weapon or whatever is in the hands. Also, I do not use a primer on my figures, I find the paint covers fine and primer tends to fill in some of the details.
Hope that helps.
Posted by Anonymous on Monday, January 17, 2005 10:37 PM
I tend to assemble my figs as much as possible, one reason for that is to putty over joints. Sine I use putty I also prime the figs and parts.
Posted by Anonymous on Tuesday, January 18, 2005 12:17 AM
Thanks.
Posted by rjkplasticmod on Tuesday, January 18, 2005 12:34 PM
I always assemble first, as much as possible, then paint.
Regards, Rick
Posted by ajlafleche on Tuesday, January 18, 2005 1:22 PM
Depends.
Painting on the sprue is a waste of time. You have too much clean up to do on plastic figures to do this.
You should prime. Use your airbrush to lay down a coat of light complimentary colored paint. This will help in seeing fine seam lines and other flaws you're going to need to fix. The airbrush will cover without a loss of even the finest detail.
Assembling before or after painting depends on two things, the pose and the engineering of the figure. Some figures, Pegaso for example, are usually so well designed there are no gaps to fill. The pose will also determine paint/assembly sequence. If an arm is posed in such a way a surface is visible but would be hard to paint, I will paint first and do any touch up later. I tend to paint weapons and webgear before attaching to insure better coverage.
Posted by Anonymous on Tuesday, January 18, 2005 6:26 PM
Only problem is, I don't have an airbrush. Only old fashioned brushes. Speaking of airbrushes, does anyone know of any places to find airbrushes/compressors for cheap? i don't really have the funds to justify the price otherwise. Thanks for your tips though.
    January 2005
Posted by jinithith2 on Saturday, January 22, 2005 4:17 PM
i think bear air has some cheap airbrushes and compressors
Posted by Anonymous on Saturday, January 22, 2005 5:07 PM
Wal Mart used to have the cheap Testors airbrush kit, which is OK for primers. lately I have been using Duplicolor white primer in the spray cans, it goes on very thin and covers well... I nearly always assemble my figure first and then add the details.
Gasser
Posted by Anonymous on Sunday, January 23, 2005 2:04 AM
Wal-Mart huh? I'll have to look into that.
    January 2005
Posted by drucifer67 on Sunday, January 23, 2005 4:25 PM
I just picked up an Aztek A470 (the A4709 set) on eBay for around $100.
____________________________________________________________ http://drucifersmodels.50webs.com/index.html --------------- "...and on the eighth day, God created polystyrene, and saw that it was good."
    January 2005
Posted by jinithith2 on Monday, January 24, 2005 2:00 PM
i have the wal-mart 370airbrush kit and the mighty mini aircompressor from there for 90dollars total
Posted by Anonymous on Wednesday, January 26, 2005 5:52 PM
nice.
    January 2005
Posted by jinithith2 on Sunday, January 30, 2005 1:41 PM
oh yeah, I usually assemble body first, than the painting of the whole thing, than I glue acc. on my suggestion is don't glue helmet before painting
