more clarification please
Posted by Anonymous on Saturday, June 14, 2003 6:57 PM
I'm still trying to get my head around 1/35 figure painting.I've been experimenting alittle but don't think i've got the steps in the right order.I tried painting the figure (an american tanker) with acrylics than gone over (when dry) with a burnt umber oil base and wiped off.This gave the figure a tanned oily looking colour.Should i have sealed the acrylic with something first?the oil base i applied was not diluted either.The next problem i have is im about to build a dragon kit of 4 german paratroops in white camo could someone please explain to me step by step the process i should take.
many thanks to all who respond ,your advise is much appreciated.
Posted by renarts on Sunday, June 15, 2003 1:35 AM
when you do washes, thin them out. 3:1 or more. This will create just a film that will settle away from the ridges and into the recesses. The burnt umber would have worked well as a thin wash. Oil washes work very well on acrylics. The acrylic resists the solvency of the turpentine/turpenoid/mineral spirits you use to thin the wash. If you are going to use an acylic wash, let the acylic base coat dry and cure first. ( at least 24 hours is what I do) Acylics, if water based, can be thinned with water. Tap or distilled. (personal preferences for some) or you can use the commercial availiable thinners for the brand of paint you are using. Or alcohol. Same effect. Once the wash has dried and set do your highlights. If you are going to paint your shadows and highlights rather than use washes you will have to take more attention to technique. And layer rather than blend paint (like in oils).
This is a pretty big subject, and whole books have been devoted to just this topic. I suggest Kalmbach publishings book Painting Realistic Military Miniatures (available through this website.....imagine that....) and Shep Paines book on dioramas. (available same place) worth every penny and will certainly give you a good oversight of the concepts and techniques.
My other suggestion would be to use the search function of the forums and do some surfing in past posts. Use every keyword you can think of in the search and you will find loads of info.
It would probobly help a little more too, if you were a little more specific regarding your questions. As I said its a big topic. Patience and perciverance will pay off, and as always practice.
Posted by Anonymous on Friday, June 20, 2003 1:52 PM
Hi Phil,
Painting figures should never be rushed. Whatever medium you are using to paint the basic colour, make sure that you use an opposing and diluted medium to do the wash or else your wash will lift off or attack the basic colour. let it dry at least 12 - 24 hours between applications. Highlighting can be done with any medium as you would drybrush protruding or raised areas and should not affect the basic coats.
Doing white is tricky as you do not get a "lighter" white and a "darker" white. I use Humbrol No. 28 - Cammo grey as basic colour and drybrush with white after applying a slightly blueish grey wash into the recesses. the almost white grey basic colour gives sufficient accent in the shadowy areas while the white highlights gives a good effect. Try it and let me know.
