Painting Black Figures
    February 2005
Posted by RadMax8 on Sunday, July 31, 2005 1:15 PM
I'm sure many of you read in the june issue of Fine Scale about secrets to painting figures for aircraft. This stuff seems to work excellent... for white guys. I've got a couple black figures in a ground crew set and I want to make them look good, too. What are the good skin colors for them? Thanks a bunch
Posted by ajlafleche on Sunday, July 31, 2005 4:33 PM
Burnt umber is a good base color. Use warm highlights, such as raw umber. Shadows can be very dark brown, such as van dyke brown.
You might get more response if the tag line is more specific. I almost past it by since it sounded like was posted by someone not will ing to try to find a similar topic.
Posted by Anonymous on Sunday, July 31, 2005 5:21 PM
Rad_remember than African Americans have a skin colour range too-from light brown to almost eggplant-but never black.
Posted by Anonymous on Sunday, July 31, 2005 6:25 PM
Burnt Umber is definitely the way to go.
If you're working in a typical AC scale you can get by with less highlight/shadow work though. I always undercoat with a desert tan, regardless of the ethnicity of the subject. It works particularly well when painting dark skinned people. Then lay the base on a little thin, so that the under coat shows through a bit, particularly on the highpoints of the face. I base with the B.Umber, as previously suggested. Shadow with Blue (French Ultramarine is what I use), and highlight with Gold Ochre or Yellow Ochre (whichever you have in your color collection. I use Gold Ochre personally because it's a little more red that Yellow Ochre and is a good flesh mixing color).
For lighter skin tones I would simply use the B. Umber as my shadow with Gold Ochre as my base, and then add white to the base as my highlight. That should give you a nice mocha tone. You can toy with the redness, regardless of how dark or light you go, as you see fit.
Just be careful not to overdo the eyes, lest they should look googly eyed. An off-white, in the yellow/red zone, sparingly applied should do the trick. For something that small, I'd probably paint them first, and perhaps even employ Shep Paine's stripe trick for painting eyes (I'm assuming you know that one Big Smile [:D]).
Post some pics when you're done.
    June 2005
Posted by MontanaCowboy on Monday, August 8, 2005 11:53 AM
In one of my LHS ( I got 3Shock [:O]) There were about 6 or 7, if I recall, different skin tones everything from a light whtite to a dark brown and they were labelled as skin tones. I haven't tried them yet, but hope to.
"You know, Life is like a Rollercoaster. Sometimes you just die unexpectedly." No wait, that's not it.
