Question about uniforms
Posted by Anonymous on Monday, July 7, 2003 3:06 PM
I would like to know what the point of putting shadows on a uniform is. wouldn't the existing light take care of that problem? I can understand the highlights on the uniform. but why waist time and paint on the shadows?
Posted by nzgunnie on Monday, July 7, 2003 7:48 PM
It is to do with contrast, look at the wrinkles in your shirt, see how wide the difference is between the lightest area and the darkest? This is because of the light, the material is the same colour in both places. However because when you scale down a person sized thing (a figure) you are still looking at it under a 1:1 scale light source, the depth of the detail will not produce the correct tonal range just purely using light. So to represent the depth of the full sized object you need to help add the illusion of depth by painting in the shadows. It is the same reason you paint highlights, what was your understanding of the reason for highlights?
Otherwise your figure looks flat, and all the detail will not stand out as 3 dimensional.
