Great medium for making gun slings, etc.
Posted by Anonymous on Sunday, April 30, 2006 9:33 AM
I have started using solder as the medium for making gun slings.
It's the standard solder you use for electronics soldering (60% tin, 40% lead) but the type I got is about half the usual thickness. It's described as "Very Fine Electrical Rosin Core Solder". Its diameter is.032 inches, similar to the tip of a slightly blunted pencil.
I pull out about a 4cm of the solder and then use long nose pliers to flatten out the solder. The pliers are smooth on the inside. Obviously the more you flatten, the fatter the solder gets. I estimate that about 2.5cm is about right for a 1/35 rifle.
I compromise and go for the right width with a little extra thickness which helps me to glue it onto the rifle easier.
I did 5 figures this morning and I'm pleased with the results. It's easy to work with, flexible and can be easily glued to plastic. It's also very inexpensive I bought a small container for USD$3 and this will last years.
I never could get masking tape, plastic, etc. to work and old tricks like toothpaste tube and wine bottle tops are very hard to find - they are all now plastic based.
Posted by Anonymous on Sunday, April 30, 2006 10:21 AM
Hello,
Rifle slings can be a bit tricky. Found that black electrician's tape works best for my meager skills. The sticky side I lay flat on a piece of flat styrene. I then use a metal ruler and sharp exacto knife to cut the desired length/width of the sling...paint(watercolor) both sides with the desired color. I glue the ends back over the sling for the loops and let dry. Last, I glue the ends of the loops to the ends of the rifle. The tape does'nt fall apart like paper and I get the flexibility I need to wrap the sling around a 1/35 figure's torso.
Semper Fi
Posted by Anonymous on Sunday, April 30, 2006 11:54 AM
Thanks Ray
I like the solder becuase I can bend it to a more natural shape. When I've used masking tape or similar material the sling just hangs like a "u" from the rifle. With the solder I can shape it better.
Posted by Anonymous on Monday, May 1, 2006 2:06 PM
Shep Paine uses solder for everything. From wiring and hose in engine compartments, to seat belts and straps. He flattens it oput, much as you do. Works great. It's basically a poor man's lead foil.
It's one of the tips in How To Build Dioramas.
Posted by Anonymous on Tuesday, May 2, 2006 8:05 AM
Plymonkey
I have that book, but haven't read it in ages. I'll have to dig it out and see what other tips it has for other problem areas of mine.
Posted by Anonymous on Thursday, May 11, 2006 1:55 PM
Cutting straps from the foil tops from champagne bottles works well.
    January 2003
Posted by gburdon on Friday, May 12, 2006 1:11 PM
Neil;
Great idea. You can also find soft metal that will work for slings on items other than toothpaste tubes and wine bottles. Check the tops of yogourt containers, pill bottles, pudding cups etc. sometimes you will find exactly what you need.
Cheers;
Gregory
VETERAN - (Noun) - Definition - One who signed a blank cheque as: “Payable to The People of Canada, Up To and Including My Life."
Posted by Anonymous on Saturday, May 13, 2006 8:18 AM
The reasons I like the solder better than cutting lead or metal from wine bottle tops, etc. are speed, ease and consistency.
With the wine top method you have to trim it down to the right length and width. I could never get it to look right or be consistent over multiple figures.
With the solder I pull out a short length, flatten it out with the inside of my long nose pliers and trim to the right length.
For me its faster, easier, more consistent and better looking than any other method.
Now, if only I could paint the rest of the figure to look as good as the strap!
Thanks
Neil
    September 2004
Posted by Abdiel on Saturday, May 13, 2006 10:19 AM
I haven't used the solder wire method, but I've had great success using the foil that comes with embossing kits. It's thicker than kitchen foil, cuts easily and retains its shape well.
I think the advantage to it is being able to use it for greater widths. For example, I used it recently to create the sleeve ends of tow cables scratch built from twisted copper wire. The results were excellent!
Cheers!
Eric
    January 2003
Posted by gburdon on Saturday, May 13, 2006 11:49 AM
 neilc wrote:
The reasons I like the solder better than cutting lead or metal from wine bottle tops, etc. are speed, ease and consistency. With the wine top method you have to trim it down to the right length and width. I could never get it to look right or be consistent over multiple figures. With the solder I pull out a short length, flatten it out with the inside of my long nose pliers and trim to the right length. For me its faster, easier, more consistent and better looking than any other method. Now, if only I could paint the rest of the figure to look as good as the strap! Thanks Neil
Neil;
To each their own eh? I normally tape the material to a glass drink coaster and cut it with a steel ruler and a sharp blade. I have used solder as well and had great results too.
Post some pics of your work.
Cheers;
Gregory
    December 2003
Posted by spector822002 on Tuesday, May 30, 2006 12:47 PM
I use foil from  the seal in a coffee can ,cut into measured strips and emboss with multiple passes with the end of an Xacto  pin vise ( the grip )   It gives the foil the look of fabric used in some slings I have seen .
