this might be a bit off topic
    March 2004
Posted by Mikeym_us on Sunday, August 27, 2006 9:53 PM
but I thought I might share a few pics of a authentic German Bayonet for the Mauser Rifle don't know if it was used with the Masuer model 91(manufactured in 1891. which my grandfather procured as a war trophy during WWII) 7.65mm rifle or the Mauser model 98 (which I believe was manufactured in 1898)which I think was 8mm.
I got this particular bayonet at a yard sale for only 10 dollars and was told this was manufactured in 1936 which would explain the lack of Nazi markings since Hitler did not come into power until either 1937 or 1938.
The bayonet is held in place with a pair of "S" springs which are inside the scabbard which is I believe was hand forged by a blacksmith due to the lack of a seam line.
On the workbench: Dragon 1/350 scale Ticonderoga class USS BunkerHill 1/720 scale Italeri USS Harry S. Truman 1/72 scale Encore Yak-6
The 71st Tactical Fighter Squadron the only Squadron to get an Air to Air kill and an Air to Ground kill in the same week with only a F-15   http://photobucket.com/albums/v332/Mikeym_us/
    August 2004
Posted by Thehannaman2 on Monday, August 28, 2006 1:54 PM
Since it was made in the '30's, I imagine that it was made for the 98 model.  But it would probably fit everything from the 91 up.  I have a 95 model and my bayonet looks very similar to that one.
Hitler was in power (full force) in '34.  But Mausers were being made in other countries as well.  Many were being made in South America.  My 1895 is a Peruvian 7mm that was stamped 1909.  That little bayonet could be from almost anywhere.
Thanks for sharing!
Justen
"The distance between genius and insanity is measured only by success."
Member IPMS Niagara Frontier. "The BuffCon Boys."
IPMSUSA Member 45680
    March 2004
Posted by Mikeym_us on Monday, August 28, 2006 2:21 PM
though there is one thing some people don't know about the German Mauser models 91 through 98. This is something my grandfather told me about the war in Europe. The Mauser rifle wheter using 7 mm through 8 mm could use different ammo than what it was designed for. The Mauser 91 is chambered for 7.65 mm but can fire 7mm and 7.62 mm ammo. And the 8mm Mauser 98K can fire 7.65mm and 7.62mm ammo. My Grandfather told me captured German soldiers were found with captured 7.62mm ammunition liberated from dead american soldiers for use in their weapons due to shortages in ammunition due to key allied bombing missions on ammunition factories. Allied soldiers fired the capture german rifles with both the ammunition that was for the particular rifles and then used the ammo for the M1 Garand(which is 30-06) and were impressed that it worked well with the German rifles. Oh and BTW the difference between 7.62mm and 7.65mm ammo is a amazing .03mm.
Posted by Anonymous on Monday, August 28, 2006 11:36 PM
My Yugo-Com 24/47 Mauser came with a bayonet which looks very much like yours. It fits just as snug on my Czech VZ24 Mauser too, which is no surprise, since the Yugo is a copy of the Czech rifle, only with the medium action, rather than the full sized action (the German K98 was actually inspired by the Czech VZ24 rifle as well, which is an odd sort of turnabout, since the basic rifle was a German design to begin with). I think that, as long as the rail is the same, any Mauser bayonet should fit on any Mauser, no matter when it was made or in what country it was manufactured.
However, the only Model 91 I'm aware of is the Argentinian Modello 1891, made in Germany for Argentina (and nearly identical to rifles made for Turkey and Belgium at the time as well), and there is no rail present, so it won't work on a '91. You sure your war trophey isn't a K98 or an old 1898? Might also be a Czech or Belgian made variant. BRNO and FN both made Mausers under lisence, with their own design perculiarities, and both factories were appropriated and turned to service the German war machine, after the two countries fell. Both also made their versions for other countries for years, as did Germany. What are the markings on the receiver? Are they in German? Is there a year or a model number?
 Don't know about the compatibility of ammo though, but unless the casings were identical, you can't (or at least really, really shouldn't) really swap ammo like that. The diameter of the main length of the casing is usually the same for common military cartridges at that time, but the overall length of the casing and the draft on the neck differs from considerably, so I'd be a little sceptical about ramming any old round found on the battlefield in there. I could jam a .30-06 round in my Mausers, and it would almost fit, but it's too long. The 7.62x54Rmm rounds for my Mosin-Nagants won't fit at all, and havn't heard of the use of captured US ammo either. Considering the .30-06 round is too long (observe the pic I've attached), I'm not sure I'd buy that. It seems more likely (and is certainly widely reported) that they simply grabbed enemy weapons and used enemy ammo for them instead, when ammo for their own weapons ran short.
 Of course, this is simply what I know, having researched the Mauser rifle fairly extensively, since I collect them. But I'm open to the idea that there are things I'm not aware of. Any info on that rifle you can get would be, at the very least, interesting. Serial numbers, mfg dates, mfg names, codes, proof marks and national crests. Is the bolt handle straight or turned down, and if turned down, is there a pocket cut in the stock for it? What are the sling swivels like?
 My uncle has a Mauser that his uncle brought home from the ETO. It's a very rare and very ugly VK-98, which was a rifle made from unfinished parts of K98s and issued to the German populace for home defence in the last days of the war. It had a grossly unfinished stock, choppped to sporter length, and often a cheap, stamped trigger guard. Quality varried considerably, from rather decent to crap. His example isn't that bad, but looks like an inexperienced attempt to sporterize a standard issue K98.
    March 2004
Posted by Mikeym_us on Tuesday, August 29, 2006 3:16 PM
well the 1891 that belongs to my grandfather was clearly stamped Berlin and the date 1891 but I don't remember what the rest of the words were I would have to look at it again since it is sitting in a local museum right now. I do believe it does have the rail plus it has the curved bolt versus the straight bolt as well. BTW the K98 has a different stock than the 91 which looks like it could fold. the 1891 has a solid stock. as for compatibility the 8mm looks narrower than the 30-06. But as for the 7.65 vs 7.62 I would have to grab one of the bullets from one of my magazines for my 30-06 to compare the diameter.
Posted by m1garand on Wednesday, August 30, 2006 12:35 AM
I have 98K Mauser as well as M48 Yugoslavian Mauser rifles.  Very nice rifles.  My 98K was captured by the Soviets and was imported, so it has very little markings.
Anyway, as for compatibility of both 30-06 and 8mm mauser, even if 30-06 chambers into mauser, I would not fire it in that gun.  Desperate times calls for desperate measures and I'm sure Germans were just desperate for ammo.
    August 2004
Posted by Thehannaman2 on Wednesday, August 30, 2006 11:15 AM
I can't imagine that the 30-06 would fit since the cartiridge is so much longer.  And if it did, it would have to suck trying to get the brass out since I imaging that it would burst.  Definately not good for the breach.
Justen
    March 2004
Posted by Mikeym_us on Wednesday, August 30, 2006 1:57 PM
you have to admit though that casing designs in Germany during WWII were different than today. American and Britain used the same caliber but the casings were different. While the germans used a completely different design basically a wide rim design at the primer end. The 8mm bullet pictured above is a "modern" 8mm projectile and who really knows what the original looked like and I don't think anyone who has a original 8mm bullet for the 98k will want to try to test it for safety reasons. Though it really wouldn't take much to mill down the 30-06 casing to fit the Mauser rifle though I do believe it would fit the model 91 Mauser due to the closeness in size. Though I will have to look at both bullets to make sure.
BTW that 30-06 casing up above is a original 1940's vintage Armor piercing round.
Posted by SNOOPY on Wednesday, August 30, 2006 8:24 PM
Just to my two cents, I was watching the History Channel not to long ago, and the expert they have who works at the Aberdeen Arsenil and Amo Museum said that a lot of German small firearms could and did except Allied (mainly US) ammo.  I am not going to say which small arms but it is possible.  I beleive the luger was one of those small arms that could actually fire the .45 cal. even though it was designed for a 9mm casing.  The usually run once a month and most of the time it is on a Saturday morning.  Sorry I am no expert or even a collector but I do love the History channel.
Posted by Anonymous on Wednesday, August 30, 2006 8:42 PM
It doesn't. In fact, there are slight indentations in that '06 casing just from the light pressure I applied, and the bolt didn't come anywhere near home.
Sure you could mill it down, that's how reloaders make cartridges for rifles that have ammo types that aren't easy to come by, like the Steyr 1895, but machine shops aren't readily available in the field, and who wants to pull the slugs and dump the powder on a handful of cartridges, then reload them all after all that machine work anyway, when they could just pick up a weapon that was designed for that cartridge and get back to fighting?
 Surplus ammo is still readily available for most of the popular vintage, surplus rifles, and much of it is actually in good working order, though it's nearly all corrosive. There are plenty of sources for original 8mm ammo. I don't have any, and don't care enough to want to get any, as the new ones work just fine and aren't corrosive, but it's out there if you really want it.
 I don't want to get into a, eh-hem, "exacto knife" measuring contest about it, but barrels are machined to specific dimensions and there's really not that much "slop" to allow for minor differences in casing shape and design. A new casing isn't going to differ that much from an old one, since it has to physically fit in the chamber. The period 8mm cases I've seen are the same as the new casings. You can't get a wider rim to work without modifying the bolt. It's machined for specific dimensions, as is the extractor.
 A smaller bullet will work, but if it's too small, the least you'll have to worry about is that it'll be grossly inaccurate, and will likely damage your barrel beyond repair. It could even be dangerous. Damage to the casing, while trying to force the proverbial "square peg" into a "round hole" can be dangerous too. Even if you made it work, and managed to pop off a shot without the rifle exploding in your face, good luck getting the casing out. Good way to make rifle worthless when you need it most.
 Anyway, I'm still hitting a wall with the Mauser 91. My sources say the Argentine model, which was also exported to several other South American and European countries, is the only Mauser bearing the 1891 title. It was made in Germany and exported to Argentina, but was not issued officially to any German forces. The only German Mauser between the Model 79 and the classic G98 of WWI fame is the 71/84, which was an update to the Model 71.
 The Argentine 1891 (http://www.surplusrifle.com/argentine1891/index.asp) bolt featured the very infantile stages of what would become the classic Mauser bolt. You are correct about the caliber though. It was 7.65mm. But the rifle differs in many ways from the classic Mauser in shape, the most obvious being the Mosin-Nagant style magazine sticking out of the bottom, in front of the trigger guard.
If that is indeed your rifle, then I did figure out the bayonet situation, and in answer to your question as to whether or not your new bayonet would fit, the answer is no. The bayonet for the 1891 was similar in basic design, but the rail is on the bottom of the nose cap, rather than in front of it, as on the G98 and 98k, so the ring on the hilt, that fits around the barrel has to be farther away from the blade than on a bayonet for a later Mauser. That's assuming what you have is indeed the same rifle I'm talking about. Yours says Berlin on it, so it was almost certainly made at the Deutsche Waffen Und Munitionsfabriken arsenal, and it probably says so somewhere on the reciever. In fact, I'm looking at the side rail of an Argentine 1891 in a picture right now, and it says "Mauser Modelo Argentino 1891, Deutsche Waffen-Und Munitionsfabriken, Berlin".
 What you want to do is check out the top of the reciever and see if there's a national crest up there. That will tell you who it was made for. Most likely, it's the Argentine national crest, which has an oval with two hands shaking and a torch (which looks an awful lot like a santaclaus hat on a stick), and horizontal lines from the middle to the top. The oval is surrounded by a wreath and there's a sun rising at the top of the whole motif. There were other crests too, that denoted rifles issued to different branches of the Argentine military, as well as miltary academies. It's also possible that it was made for another country though, so the crest is what matters for identification. If it says "Deutsche Waffen-Und Munitionsfabriken, Berlin" and a year, instead of a crest, then it was made for the German army.
My Czech VZ24 Mauser was made by BRNO and bears the BRNO markings on the side rail, with the rest of the writing in Czech (but the crest, which has been largely obliterated by a grinder) is the Romanian crest of King Carol, which means that the rifle was made for export to Romania for use in their army. The only non-matching serial numbers are on the bolt handle and the floor plate of the magazine.
That your rifle was taken as a trophy in the ETO during WWII means that either it was never exported, or had been sold back, possibly as part of an exchange for a shipment of newer weapons, and was pressed into service as part of the last ditch effort in the waning days of the Reich.
    March 2004
Posted by Mikeym_us on Wednesday, August 30, 2006 8:53 PM
a 9mm luger firing a 45 caliber bullet that can't be right. I could buy that with the MP40 though that is also 9mm it looked like it could fire 45 caliber slugs. well I looked at the 7.65 mm bullets I have and compared them to my stash of 30-06 bullets and the casings are just about the same diameter. though the casing is shorter than the 30-06 casing. the slug itself is almost the same length as the other half of the 30-06 casing!  all in all the 30-06 and the 7.65mm munitions overall length wise are just about the same. BTW I found out that 30-06 ammunition can fit onto a 8mm stripper clip.
Posted by Anonymous on Wednesday, August 30, 2006 9:00 PM
Well, pistols are a different story, as a pistol cartridge is generally the same diameter, from rim to mouth, with no shoulders. Everyone knows you can fire .38 specials in a weapon chambered for .357 Mag. But .45 is visibly bigger than a 9mm, and I'd guess your safe and physically possible margin for error is no more than about .020, +/- a thousanth or two (the approximate difference beween a .38 Special and a .357 Mag), so any physical, dimensional difference you could actually see leaves me scratching my head, especially using bigger in smaller. A .45 is nearly .100 bigger than a 9mm, so again, scratching my head. Of course the History Channel has been wrong on a thing or two, but it seems I've heard that bit of info myself, so I won't discount it out of hand. And, I'm more of a collector than a shooter, so I'll happily yield to the knowledge of the more active shooters amongst us.
    March 2004
Posted by Mikeym_us on Wednesday, August 30, 2006 9:28 PM
but it is funny how he got hold of the rifle. He (my Grandfather) was on patrol in France after the D-Day invasion when he came across this French hunter hunting deer out in the woods so he stopped the hunter and asked for identification and then informed the hunter that the French populous with the exception of the Free French Army were not allowed to posess firearms. So all in all he confiscated the rifle and several hundred rounds of ammunition and he sent it home for his parents to hold onto till he came home. and its funny you meantioned the Mosin Nagant he also has one too but this came from his brother in laws estate after he died a few years ago. I actually mistook it for a SKSTongue [:P] It's not like I have actually seen one beforeTongue [:P]
Posted by Anonymous on Wednesday, August 30, 2006 10:33 PM
Ah! Well that makes more sense. I would more likely expect to see an ancient export firearm like that in the possesion of a civilian than in the hands of a German soldier. That's a neat story though. Regardless of what model is it, it's a great collectors piece and a testement to the craftsmanship of Mauser. It's great that  your family donated it to a museum so that everyone can enjoy it.
 My Mosins are both dated 1942 and were made at the Izhevsk arsenal. Of course I only bought mine at a gun shop for less than $100 a piece. No cool story behind them. But they are in fantastic shape. Arsenal refurbished, with fresh blueing and a fresh coat of varnish on the stocks.
 Do you have access to your Grandfather's Mosin? I'd be interested in details. You can find out all you ever wanted to know about it here http://7.62x54r.net/
Posted by m1garand on Thursday, August 31, 2006 7:26 AM
.45 ACP WILL NOT fit into a gun that is designed to accept 9mm Luger (Parabellum/9X19). Diameter is way too off and just like what others have said, it will be phisically impossible to fit .45 ACP cartridge into a chamber of a firearm made for 9mm.
However, U.S. Grease gun had modifications to accept 9mm Luger.  Soldiers simply had to change the barrel and the magazine to shoot 9mm.
    March 2004
Posted by Mikeym_us on Thursday, August 31, 2006 10:10 AM
well this particular Mosin Nagant was manufactured in 1930 which would make it a Model 1891/30 and it had a star and arrow on the top of the barrel near the reciever with the Hammer and sickel (however that is spelled) on the reciever housing.
    August 2004
Posted by Thehannaman2 on Thursday, August 31, 2006 11:49 AM
And if you do have a Luger that can fire a .45, you're going to be a millionaire very soon.  There were only two made and one was destroyed in testing.  The only .45 caliber Luger in existance went for over a million bucks at auction a couple of years ago.
Justen
Posted by Anonymous on Thursday, August 31, 2006 7:26 PM
If it's a full sized rifle then it's a 91/30. The M38 and the M44 were chopped down 91/30s, so they could have dates stamped on them that pre-date the existance of the model.The only difference between the 38 and the 44 is the bayonet permanantely fixed to the barrel of the 44. I had a suspiscion that yours was an M44 because you said you though it was an SKS, which has a permanantly affixed bayonet.
 My M38 has an M44 stock for some reason. It has the groove cut in it for the bayonet, but there is no bayonet on the barrel. Both my 91/30 and my M38 were made in 1942 at the Izhevsk aresnal, indicated by the arrow inside a triangle.
 The star with the arrow is the symbol for the Tula arsenal, so that's where it was made. The 91/30 actually began production in 1927.
Remington actually made M91s at the start of WWI, for the White Russians in their fight against the Reds.
    March 2004
Posted by Mikeym_us on Thursday, August 31, 2006 8:38 PM
well it looks full size but I never said anything about a bayonete. BTW guys the 8mm Mauser was also chambered for the 7.92mm ammo as well.
