Conan the Barbarian
    June 2003
Conan the Barbarian
Posted by Avus on Monday, September 18, 2006 2:51 AM
This is my entry for the figures GB, but I thought I'd post a pic here, too:
It's Pegaso's 90mm "Cymmerian Warrior" painted entirely with Vallejo acrylics. The figure is as usual a great cast with crisp detail and an overall good fit (almost no filling necessary).
More pics in the GB section. Critics and comments are welcome!
Klaus
Thanks to ImageShack for Free Image Hosting
Posted by ajlafleche on Monday, September 18, 2006 9:28 AM
Very nice work, great skin tones. In this scale, dry brushing highlights doesn't give as nice an effect as actually highliting (pants and boots) the colors look muddied (not muddy). Go to http://www.acrylicosvallejo.com, choose model color from the drop down menu and scroll to the bottom for a really good tutorial on a better technique than drybrushing. It takes longer, but the results are worth it.
    June 2003
Posted by Avus on Monday, September 18, 2006 10:55 AM
Thanks ajlafleche, I really appreciate your comment!
The skin is painted with the technique described in Vallejo's guide (except that I tried to preshade). Personally I think that dry brushing is good for ground, hair and fur.
The only place I "cheated" are the trousers, since black (more than white to me) is a bit a pain in the @ยงยง to me. So I dry brushed them with a very dark grey.
As for the mud you're right probably I should give it a wash of burnt umber or similar.
Klaus
    May 2006
Posted by MortarMagnet on Monday, September 18, 2006 11:38 AM
Crom!  That's really good work.  I think you did well on the face.
Brian
    May 2006
Posted by Panzerjaeger on Monday, September 18, 2006 1:10 PM
Wow! Avus! You nailed it. Never mind the rest, I think this is frikkin' brilliant! It even looks like Arnie. Great job. I am really impressed.
Cheers, Arthur Approve [^]
Work, work, work! You gotta put models on the table somehow!
Posted by ajlafleche on Monday, September 18, 2006 2:51 PM
I guess you misunderstood the muddied comment. I wasn't refering to mud. per se, but to the collors being muddied or blurred rather than blended like you did with skin tones. Yeah, careful dry is about the only same way to highlight fur. I did that on my versio of Latorre's 5th Century Celt (Another Arnold based figure).
For black, have you tried starting out with very dark gray as the base color, using true black only for the shadows and adding blue (cool) or flesh (warm)  to the black for highlights?
    June 2003
Posted by Avus on Tuesday, September 19, 2006 2:02 AM
Thanks for your appretiation MortarMagnet and Panzerjaeger!
ajlafleche, indeed I misunderstood you. Now I see your point. Actually by dry brushing I was trying to simulate dry mud and dust which is kind of blurry, but you're right I probably should have blended at least on the boots.
Thanks for the hint on black I'll give it a try on my next black figure. Is there a reason why you suggest to add blue or flesh to the base color and not grey or white? As far as I've noticed black tends to grey when worn out.
Klaus
Posted by ajlafleche on Tuesday, September 19, 2006 7:58 AM
It's one of those things I've learned from my mentors. Adding white creates too stark a contrast and grey might not show as well. Using a light blue will give the black a cooler value, which you'd want if you were depicting a figure in winter. Flesh gives it a warmer value, a figure in summer. Alternating these in a figure with several black items will give you a nice variety of shades on a mochromatic figure.
    June 2003
Posted by Avus on Tuesday, September 19, 2006 11:23 AM
Thanks for the insight ajlafleche. I'll keep that in mind next time I'll be working on a black figure (Pegaso's Ninja?!).
Klaus
