Darth Vader Stance
    October 2006
Darth Vader Stance
Posted by epaulk on Monday, October 30, 2006 9:53 PM
Hi;
I normally build cars and Starships, but today I just started my first vinyl figure. It is a AMT Darth Vader. The kit looks really good, but while I do the dry test, I notice that the stance of the figure is a little too ballet for Dark Side in person.
Is there any easy way to change the stance or someone can point me to a website, please?
Here is a sample of the stance of the kit:
http://home.comcast.net/~gdaley57/039xlx.jpg
Here you can see samples of the stance I want:
http://cornerstorecomics.com/SDCC/images/sdcc06_sw_sith_L.jpg
http://www.monstersinmotion.com/catalog/images/sw/mace123.jpg
Thanks!
Edgar A. Paulk http://www.modelosaescala.com/
    June 2003
Posted by Avus on Tuesday, October 31, 2006 1:43 AM
Well, what you are up to implies changing the posture of arms, legs and hands.
This is not too difficult but if it's your first attemp at doing a conversion I'd try on a scrap figure first.
Basic technique is the following (let's consider an arm, for example):
  • Cut the arm at the ellbow (knee if you are working on a leg, pulse on a hand etc.), removing quite a bit of the ellbow itself.
  • Drill a hole in each art of the arm to insert a metal wire (brass or soft steel); this way you can bend the arm to the desired position
  • Fill the gap with putty and recreate folds an texture of the cloth.
Klaus
Thanks to ImageShack for Free Image Hosting
