1/72 Pegasus Hobbies Waffen SS set 1 (Set Review and Waffen SS Camo)
    April 2006
Posted by Panzer_Grenadire on Monday, November 27, 2006 9:00 AM
This is Pegasus Hobbies Waffen SS set 1, hope you like both the pictures and the review.
I have tried to reproduce several types of Waffen SS camouflages, namely oak leaf (spring/summer; autumn/winter), blurred edge (spring/summer; autumn/winter), plane tree (spring/summer; autumn/winter), palm/forest tree (spring/summer; autumn/winter).
I also tried to add minor details like Waffen SS ranks on the colars, scatches on mess-tins and other small things....
Any suggestion and opinion are more than welcome.
Cristian Florescu
http://i74.photobucket.com/albums/i267/Panzer_Grenadire/91.jpg
PEGASUS HOBBIES 1/72
WAFFEN SS 1943 - SET 1
"1st SS Division LAH"
Manufacturer
Pegasus Hobbies
Scale
1/72
Set Code
7201
Year
2004
No. of Figures
46
No. of Positions
17
Aspect
High
Material
Soft Plastic
Optimal Period
1943 -1945
Review
„Waffen SS 1943 - Set 1" represents the first German Army set launched by Pegasus Hobbies on the 1/72 soft plastic figures market. Even if the box is not impressive at all and it can be appreciated as an ugly one, when it is opened, the owner remains fascinated by the high quality of details and poses. These factors, corroborated with some innovations, led to a set exhaling a mix of vitality, force and realism and it can be considered as a reference set that increased the challenges, propelling the producer in the top of the best companies in the field.
As the title and subtitle stress, there are reproduced infantry men from Waffen SS, (1 SS Division „Leibstandarte Adolf Hitler") during the Kursk battle in summer 1943. On the other hand, these soldiers can be used in any period of WWII, especially after 1943, representing both Waffen SS and Wehrmacht troops, the difference being realized through the camouflage patterns.
The uniform that equips all the soldiers consist in camo smock M38, regular trousers and marching boots. Moreover, all the figures have helmets covered by camouflage canvas.
One of the advantages of the set is that the figures can be used not only in summer, but also in colder seasons, the thickness of the uniform allowing this fact.
All the soldiers wear the "Y" straps and almost all have gas mask, bread bag, mess-tin, canteen and shovel. As regard the last item, this is provided separately for some figures that have a hole for this purpose. Even if it stays good, for a better fixing it is recommended to be glued. Taking into account the material, a very soft plastic, it can be used only super glue, which amazingly have great success. The same adhesive must be used and for gluing the heads of two poses of prostrating soldiers for which the producer decided to provide them separately, aiming to make them credible.
Furthermore, concerning the entrenching tool, there are three different models. One has the bayonet attached to the shovel, the other has just the sheath and the frog attached and the last has nothing attached. The models can be fixed randomly on the figures, but at a careful look, it can be noticed that some figures have the bayonet handle sculptured in the area where it must be put the entrenching tool, so it is advisable in this case to fix entrenching tool that has attached the sheath and the frog.
The armament is characteristic for the period as well for the standard endowment of a German Army infantry platoon in 1943, in this regard not abounding in MGs or MPs. The soldiers have fifteen Kar 98K (one with scope), one MP40 one MG34, and each soldier has the appropriate ammo pouches. It must be emphasizes the fact that most of those with 90Ks and the one with MP have straps at their weapons, a very important and correct detail, but extremely rarely found in other sets.
The poses are realistic and very well done, nine figures standing, four crouching and four prostrating. All are really dynamic, most of them being different than other sets. From such poses can be mentioned the soldier preparing to fix the bayonet to the 98K, the soldier which gets ready to take out a grenade from the boot, the running soldier holding his helmet on the head and the soldiers that are to extract ammo from the pouches.
The officer's pose is attractive, the details being well realized and like in reality, he does not differ too much than the rest of the troop. In fact, he is the only one possessing MP40 and his gear consists in two ammo pouches for MP, pistol, a grenade, map case and binoculars. The last mentioned item is a special one, being the only one in the scale with the back lens protected by a leather case, as it was at real models. From this minor detail it can be remarked the study and attention granted by the sculptor for the set. A similar system for protecting the lens has some figures from „WW2 German Motorised Infantry" manufactured by Preiser, but the cases are on the back of the figures and not on the lens. In soft plastic, a related system can be found at one of the officers from „German Infantry (late War) by Caesar, but and this one is not protecting the back lens.
At their turn, the machine gunner and the servant are excellent, even if they are in a so called "classical position". A major detail rests in the fact that the servant has the 98K, as it was his endowing according to the KStN. Unfortunately the gunner misses his personal weapon, namely the pistol, but it can be assessed that he wears it on the belly, where it can not be seen due to his pose.
Two figures are almost identical, those that are crouched and fire with the 98K, but there is at least one difference, one having the scope. More diversity can be made trough assembling on the soldiers different types of entrenching tools.
Many figures have grenades in their marching boots and one has a grenade under the belt. Moreover, there are provided two poses of soldiers throwing the grenades, and they do it very persuasive. Their poses are really dynamic and dissimilar than the other soldiers doing the same thing that are encountered in almost each set referred to the German Army. As it was mentioned, both are excellent, but the prostrating one looks like it was inspired from a famous photo of WWII.
Regarding the uniform, there is a small inadvertence at the M38 camo smock. It can be notices at some poses that it has strings till the bottom, while the reproduced type was pulled over the head, its opening being almost till the button belly. It is a detail visible just at several poses, and taking into account the high quality of the set it can be overlapped, especially because it can be hidden when the figures are painted.
The upper part of the smocks are nicely realized, even if these are tight and not lose, like there were worn in general by the troops. Another attractive feature is that in spite of being infantry men, several figures wear goggles on their chests. The detail is in fully accordance with the reality, taking into account that in 1 SS Division "Leibstandarte Adolf Hitler" there were many SS Grenadiers Regiments, troops that intensively used various types of vehicles, in order to closely support the Panzers in combat.
Furthermore, on the sleeves the figures have the ranks, like there were at the original models of Waffen SS camo smocks. It must be stressed out that if it is desired to use this set after 1943, the ranks must be erased. The anatomy is excellent as well the faces that are extremely expressively.
It should be emphasized that there are no differences between the size of the weapons or gear between different poses, flash is at pretty low levels and easy to remove.  As well, excess of plastic does not exist and the used material accepts very well the painting, even if it has the tendency to give a gloss aspect to any paint. For this reason and to have a matt appearance, it has to be added in more layers as usual.
One problem may be raised due to the fact that the figures are manufactured from a very soft plastic and several gun barrels are bended. There are more solutions in order to solve the issue, the easiest consisting in soaking in hot water and immediately after readjust them in the correct position.
The figures reviewed here are perfectly compatible by size and camouflage uniform with  the soldiers from Caesar "German Infantry with Winter Gear",  Italeri/Revell "German Elite Troops", Revell „German Infantry", Esci „Nebelwerfer 41", Preiser „WW2 German Pak40 Crew" as well with some from Pegasus Hobby "Germans in Berlin 1945".
Another set treating an equal theme is from the same company, namely "Waffen SS - Set 2 "1943 Kursk LAH", Pegasus Hobbies having the brilliant idea to develop an identical topic inside two distinctive sets. But from idea to fully realization is a long way,  and even if "Waffen SS - Set 2" is a good set, still more interesting at least taking into consideration the great number of poses, but unlike Set 1, there are some differences between the figures, being smaller but definitely not at 1/76.
It must be said that the two sets are quite compatible, completing each other,  but nevertheless, some micron differences are noticed after a good look at the size of weapons, gear and heads.
Anyway, the discrepancy is slightly noticed and with little effort and studied positioning, it is possible to put together both sets on the same diorama.
„Waffen SS - Set 1" signifies indeed an elite set illustrating an elite unit, which opened the way for other great sets manufactured by Pegasus Hobbies. Furthermore, it can be assessed as a milestone in the field of 1/72 soft plastic figures referred to the German Army in WWII, the set succeeding to put an end to the monotony of the "classical" sets, not only through the high quality of details, but also through the very energetic and realistic poses.
Historical Accuarcy
10
Anatomy
10
Poses Quality
10
Details Quality
10
Mould Quality
10
Sculpture
10
Recommendation/Utility
10
TOTAL
10
Posted by Anonymous on Monday, November 27, 2006 10:04 AM
Great review and a very professional paint job! 8)
One small thing though, even in 1/72 scale it is possble to see the difference between the Heer camouflage smock the various waffen SS smocks........its all in the stitching....not just the camouflage pattern. ;)
But we paint them as we need to eh?
 That aside, a really good review and thanks for showing it too us O8
 stuart :)
Posted by richgb on Tuesday, November 28, 2006 12:43 PM
Amazing painting on those figures especially in that scale. The various cammo styles are very interesting. thanks for the interesting review as well. Do you put these in a dio or just for display and the "fun" of painting them/
Just a quick question before i go. I'm going to paint up some 1/72 Vietnam LRRP by Esci and was wondering what your opinion was on shading and highlighting cammo uniform in this scale and what colours would you use, bearing in mind they will be in various shades of green.
Thanks again and top painting.
Rich
...this is it folks...over the top!
Posted by cassibill on Tuesday, November 28, 2006 5:52 PM
Very impressive work.  You have a very good side force there.  You'll have to find some opponents for them.
cdw My life flashes before my eyes and it mostly my life flashing before my eyes!!!Big Smile The 1/144 scale census and message board: http://144scalelist.freewebpage.org/index.html
    April 2006
Thank you
Posted by Panzer_Grenadire on Wednesday, November 29, 2006 7:43 AM
Thank you all, I am really glad that you like both the pictures as well the review, especially because I wrote them not in my mother tongue.
Indeed it's pretty difficult to realise them, and as Stuart said, "it's all in stitching...not just the camouflage pattern". Whistling [:-^] It tok me a month in order to paint these figures, but I hope the effort was not in vain....Whistling [:-^]
Morever,  not only the cammo is difficult to realise, but also the hundreds of various small details.
Indeed,  I have to find some oponents for them, but for the moment I am busy with other Germans...Smile [:)]
Once again, thank you all!
P.S. Regarding the Vietnamese soldiers, I have to say that I have never paint them, but I would try to do it with Humbrol 150, 30, 91, 180, 148.
