Tamiya Jerrycan
Tamiya Jerrycan
Posted by airtrans Crash on Monday, June 16, 2008 11:11 PM
I figured this was the best place to post.
I just wanted to advise fellow hobbyists that the tamiya 1/35 jerry can and drum set was horrible.
 the handles are all wrong, the fit is terrible and they look cheesy. I was going to use mine on my Dragon M4a3 but I might just cover with a tarp and use them for the shape.
 A man's country is not a certain area of land, of mountains, rivers, and woods, but it is a principle; and patriotism is loyalty to that principle. ~George William Curtis
    August 2005
Posted by Phil_H on Tuesday, June 17, 2008 12:11 AM
If you are talking about the old 1970's Jerrycan set (German and US jerrycans, drums and buckets), yes, it IS horrible.
There is a later German Fuel drum set  (#35186) which is much nicer and contains fuel and water jerrycans (with minute inscriptions on the cans), with separate caps and three-bar handles, fuel drums and hand pumps.
EDIT: Likewise, there is an updated "Allied Vehicles Accessory set" (#35229) which contains new tool US Jerrycans (with separate caps and handles), fuel drums, packs and other bits n pieces.
Posted by sgtsauer on Tuesday, June 17, 2008 12:38 AM
If you need a couple of the new tool cans to finish your project let me know. I would be happy to mail you a couple free of charge.
Posted by airtrans Crash on Tuesday, June 17, 2008 12:57 AM
much appreciate it Sgt, I'm going to do all I can to these... helps improve my skill.
the seam down the center of the german cans is recessed on these kit cans, they should be the opposite correct?
and both the German and American cans should have three handles? Solder wire will work for those.
Posted by Anonymous on Tuesday, June 17, 2008 8:44 AM
the seam down the center of the german cans is recessed on these kit cans, they should be the opposite correct? No, they should be recessed.
and both the German and American cans should have three handles? Solder wire will work for those. The German can should have three--not sure about the American can but I believe that three is correct for them as well.
The old Italeri Jerrycan set is still one of the  best sets on the market IMO...also the cans that come with the new DML kits are probably the best cans in plastic available...wish they would release a separate set of these...
Posted by airtrans Crash on Tuesday, June 17, 2008 10:32 PM
the Tamiya German Fuel Drum Set is done up really well though, now that I see I have it as well.
did the Americans also pain their cans for water with a white cross on it or did just the Germans do this?
    April 2008
Posted by Huxy on Wednesday, June 18, 2008 6:35 AM
Just the Germans did that... As far as I have heard/read..
"Every War Starts And Ends With An Invasion".
    September 2006
Posted by the Baron on Thursday, June 19, 2008 11:28 AM
In at least one of the old "Tips On Building Dioramas" broschures included in the Monogram 1/32 armor kits, Shep Paine showed a jig he built for scribing the seam lines onto the jerry cans included in the Monogram panzers, because they were cast smooth.
Regards,
Brad
Moderator
    April 2006
  • From: my keyboard dreaming of being at the workbench
Posted by Aaron Skinner on Monday, June 30, 2008 1:49 PM
Regards,
Brad
Shep also shows this tip in his book Modeling Tanks and Military Vehicles. It's out-of-print but you might be able to find one around.
Cheers,
Aaron Skinner
Editor
FineScale Modeler
Posted by ajlafleche on Monday, June 30, 2008 1:53 PM
 Aaron Skinner wrote:
Regards,
Brad
Cheers,
I'm curious why Kalmbach doesn't do a reprint of Shep's books.
    June 2008
Posted by Hans von Hammer on Tuesday, July 1, 2008 3:50 AM
U.S. Jerry cans have 3 handles. (I cut the 2 handles off and put on new ones made of stretched sprue.)  The water cans have a tan-colored enamel coating on the inside and a large folding-type snap-latch for the cap, as well as the word "WATER" stamped into them below the "X".  Gas cans have a screw-type for the filler tube to be inserted.  If you have a mix of gas/diesel-powered vehicles and equipment, make sure you stencil "DIELSEL" and "MOGAS" onto a few of 'em.  Vehicles with Deisel engines like the M577 Command Post tracks have a gas-powered 3kw generator on them, and the cans for it are stenciled "MOGAS".  Modern U.S. water cans are single-handled plastic and molded in either black or tan.  They're also stamped "WATER ONLY", with a small pouring-cap and an air-vent cap on top of the large cap.
I just picked up  like-new copies of Sheps' How to Build Dioramas and Modeling Tanks and Military Vehicles from Amazon.com for under 5 bucks each.  I'd lost my originals years ago and it was good to get 'em back.
Moderator
    April 2006
Posted by Aaron Skinner on Tuesday, July 1, 2008 1:57 PM
The second edition of Shep's How to Build Diorama's is in print at the moment.
Cheers,
Aaron Skinner
Editor
FineScale Modeler
