Painting non figure kit, soldiers... (look inside for explination it seems)
    April 2008
Posted by smeagol the vile on Sunday, June 29, 2008 1:20 AM
I have been looking at my dad's conte vikings, they are very nicley detailed, and he had a double or two, I want to paint them, problem is there that kind of rubbery like plastic, I dont know how to sand down the mold lines, or what kind of paint to use, and what not.
    November 2006
Posted by jadgpanther302 on Sunday, June 29, 2008 10:04 AM
I would definenetly prime them. As for sanding i'm thinking a sanding stick would work.
    July 2004
Posted by stikpusher on Sunday, June 29, 2008 4:30 PM
A set of needle files should work fine for mold line removal. I have a nice set from Tetors Model Master that did not cost much and are oh so handy. Priming your figures may be a bear though. If they flex due to the plastic, most any type of paint will flake off. Just like the old 1/32 Airfix  soft plastic figures.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
Posted by renarts on Sunday, June 29, 2008 4:47 PM
For the soft plastic figures a sharp knife works best for cleaning mold lines off. The local DIY store should have a primer made specificaly for priming plastic patio furniture that works fine for the initial prime. Once primed, regular paints work well.
    April 2008
Posted by smeagol the vile on Sunday, June 29, 2008 4:50 PM
the problem with the figures is they are rubbery, and the seams arent cutting cleanly off, and this blade is sharp, and if they dont go off cleanly, I cant sand them because its like sanding rubber.
    October 2007
Posted by panzerguy on Sunday, June 29, 2008 4:57 PM
 Try using 000steel wool I've had some success with it.Also there is an auto paint that is used to paint the inside door panels on cars it flexs with the plastic cant remmember what it's called. Try asking over in the,dare I say, auto forums.
"Happiness is a belt fed weapon"
