Painting Faces question
    June 2008
Posted by Will on Friday, July 4, 2008 3:53 PM
When i paint figures my paint brush always leaves brush strokes. so my question is how do I get rid of the brush strokes.
    April 2006
Posted by FingersEddie on Friday, July 4, 2008 6:44 PM
You need to thin your paint slightly. If your paint is old and has gotten thick, then change it for some fresh stuff. Most paints you shouldn't need to thin, if they're still fresh.
"Ask not what you can do for your country, ask what your country is doin' to you!" "If liberty means anything at all, it means the right to tell people what they do not want to hear." "Say 'NO' to censorship, it leads to a dictatorship!" http://public.fotki.com/paulyrichard/
Posted by ajlafleche on Friday, July 4, 2008 7:13 PM
What kind/brand of paint are you using?
    June 2008
Posted by Will on Friday, July 4, 2008 7:38 PM
Im using mm acryl skin tone tint base lt
    December 2007
Posted by Cosmic J on Friday, July 4, 2008 9:37 PM
FastEddies right. Sounds like you just need to thin the paint a bit. Acryllics are usually a little translucent, and often require more then one coat to get good coverage if they are thinned correctly.
Are you priming or base coating your figures?
    June 2008
Posted by Will on Friday, July 4, 2008 10:21 PM
I don't know how to prime and how do I thin the paint.
    November 2006
Posted by ww2modeler on Saturday, July 5, 2008 5:13 PM
Priming is spraying the whole assembled body of a figure (or whatever you are at before you start painting) with a single color. I use either an Airbrush or a Spray can. Some colors that I like are grey and white although everyone uses different ones. One thing to keep in mind though is not to use exotic colors that will show through on the figure.
You thin paint using thinner.....Ok, It all depends on what kind of paints you use. The best thinner for your type of paint is what the maker of the paint produces. I'm not really sure about other types of thinner though.
Good Luck,
David
On the bench:
1/35 Tamiya M26 Pershing-0%
1/144 Minicraft P-38J Lightning-50%
Numerous 1/35 scale figures in various stages if completion.
    June 2008
Posted by Hans von Hammer on Sunday, July 6, 2008 9:02 PM
For most acryilics, I thin them with rubbing alcohol. Alcohol evaporates fster than water.  Like as has already been said, priming is just a neutral undercoat of a single color that gives the plastic surface some "tooth", giving the color coat something to stick to...  I just use plain old enamel grey primer from Wal-Mart.  The cans are only a buck or so.  Since you're using acryillics, the color coat won't dissolve the primer.  Also, if you have to put more than one color-coat on, you should seal the first coat with clear flat to keep the second coat from dissolving the first one.
    March 2008
Posted by EasyMike on Monday, July 7, 2008 2:00 PM
 Will wrote:
...I don't know how to prime and how do I thin the paint...
 http://www.thortrains.net/paint1.html
Smile [:)]
    March 2005
Posted by grizz30_06 on Monday, July 7, 2008 4:48 PM
I don't like the MM Acrylic skin tone (I like the other paints in this line).  So I bought some Andrea's skin tones.  The MM one were to thick for me and I never could get the hang of thinning them.
Grizz
Denial, it's not just a coping mechanism, it's a way of life.
Posted by ajlafleche on Monday, July 7, 2008 6:12 PM
Ditto on Andrea (and the nearly identical Vallejo). Easy to find on-line if not at the LHS. Take a look here to see what they can produce.
    January 2008
Posted by 666Irish on Monday, July 7, 2008 8:06 PM
Also make sure that the brush you are using isn't too stiff. A stiff brush will drag through the paint and leave bristle marks. Spend the extra dollar or two and get good natural hair brushes.
She was only a whiskey maker, but he loved her still.
    June 2008
Posted by Will on Friday, July 11, 2008 2:10 PM
With the primer could you brush paint it on?
    March 2008
Posted by EasyMike on Monday, July 14, 2008 9:58 AM
 Will wrote:
...With the primer could you brush paint it on?...
Yes, but you want to ensure your brushcoat primer does not fill details.
Smile [:)]
