camo uniform
camo uniform
Posted by Anonymous on Monday, November 10, 2003 4:17 PM
any suggestions how to paint a camo uniform for a 1/35 figure. I have a british desert rats and a 101st airborne but i havent started it yet. thanks in advance for your help
    July 2003
Posted by Dwight Ta-ala on Monday, November 10, 2003 8:36 PM
jedi_mike8,
There are two ways in which you can paint your figures.
1.) While the parts are still on the sprue.
advantage: easy maneuvering for painting especially the tight spots.
disadvantage: Possibility of painting messed up at joints when you put the parts together. Some paint discontinuities at joint can be seen.
2.) After you have assembled it.
advantage: Smooth paint transition on joints. Avoid messing up the paint when gluing joints or other parts.
disadvantage: Difficult to paint tight spots.
I used to paint the parts while these are in the sprue but now I prefer painting after assembly.
When I paint, I usually start with the large areas like the uniform to the details. I paint the faces and hands last.
You can probably us Tamiya Dark Yellow for the uniform of the Desert Rats. If necessary you may want to adjust the tone of the color using some amounts of any of the darker or lighter earth colors like buff, flat earth, read brown or flat brown.
While it maybe considered unnecessary, I feel that spraying is better than hand painting to achieve a flat or matte finish for large paint areas. Sometimes brushstrokes can cause lumps of paint that become a bit glossy.
I use a very fine Tamiya brush or chinese brush to do the camo patterns and other details. You need to thin the paint for camo pattern properly to achieve a smooth finish.
Adding some light washes and doing some mild drybrushing can also liven up your figure.
Let me just share with you a pic of some figures I did a while back. These are of US M1 Tank Crew sporting the old US Army desert camo. This is the original pic. After posting it here the figures have already received some additional washes and dry brushing. The eyes were already darkened and redone taking away that funny look of the TC.
Hope this helps.
P.S. You can check any arts supply store in Quiapo area for things that you might need in the hobby. I cannot really remember the names of the store.
Posted by Anonymous on Tuesday, November 11, 2003 9:20 AM
thanks again dwight, we'll im gonna try to paint those camo by next week. any contact number where i can call you? tnx again
Posted by Anonymous on Wednesday, November 12, 2003 3:51 PM
how do u mix colors let's say 60% of this color and 40% of that color to make the desired color? usually camo uniforms needed this kind of mixing. thanks again
    July 2003
Posted by Dwight Ta-ala on Wednesday, November 12, 2003 5:53 PM
Before I use a medicine dropper but now I kinda guess the amounts.
Shake the paint bottle well or stir the paint to make it more consistent and easy to be sucked by the dropper. You can use say a 1ml dropper. It is usally graduated in 0.1ml so 40% can be 0.40 and 60% can be 0.60 and so on. Bigger droppers are also fine.
Mix them in a clean bottle. Thin as necessary.
Good luck.
Posted by RonUSMC on Wednesday, November 12, 2003 8:13 PM
Dont forget to check our reference gallery for colors.
http://rongeorge.com/modules/Gallery/uniforms
http://finescalegallery.com Active Kits: 1/48 AM Avenger 1/35 Sd.Kfz 251 Ausf C
Posted by Anonymous on Thursday, November 13, 2003 3:13 PM
thanks guys its a big help, ill try it and keep u updated
