Courage to Try ?
    August 2008
Courage to Try ?
Posted by tankerbuilder on Thursday, April 9, 2015 12:46 PM
I think we've hit a hiatus here . I am going to fire this back up with a build suggestion . Those of you whom have decided to take the plunge might find this in line . It's JSC's kit Nr 41 . It's like a book and this is what makes it nice . In this book you will find three complete ships ! All in the same scale ( 1/400 ) . The first two , the CZECH and the OLIWA seem to be about the same size . Well maybe the OLIWA is a quarter inch larger .Then there's the PEKIN .She's the largest . They are quite simple in that there is a printed instruction sheet that covers All three . There's nice line drawings of the first two inside the cover . The PEKIN's line drawing is on the inside of the back cover . These line drawings also point out where the numbered parts go . If they are available then I would suggest you start with these ships . The pages are done in heavy card for the frames and keel plate as well as necessary heavy stuff . The rest is cleanly printed on what seems to be a cut above regular typewriter paper . Color - fast and easy to work with . Give it a try ? Tanker - Builder Sorry about the spacing , I ain't on FireFox
