Michael Adams’ X-15-3 fatal flight, in 1/48th scale
    January 2018
Posted by DHanners55 on Wednesday, April 5, 2023 7:59 AM
The original model is by a chap named Henry Yuen and the repaints are done by a guy known as YukonJohn. They are available in the Downloads section at https://www.papermodelers.com/ (under Real Space in the "Sci-Fi & Real Space" category) but you need to register and I think you're required to make a minimum number of posts (not many) before you're allowed to download.
    March 2022
Posted by missileman2000 on Wednesday, April 5, 2023 7:54 AM
Who makes those X-15 model kits?
Posted by gregbale on Monday, April 3, 2023 6:20 PM
Once again, exquisite work! YesYesYes
Greg
George Lewis:
    January 2018
Posted by DHanners55 on Monday, April 3, 2023 3:41 PM
On 15 November 1967, Michael Adams became the first (and only) fatality of the X-15 program when X-15-3, 66672, went into a hypersonic spin and eventually broke apart. Adams failed to eject. He had reached a speed of Mach 5.2 and an altitude of 266,000 feet, and was posthumously awarded an astronaut certification.
I’ve modeled the last flights of 66670 and 66671, so I figured I should do the last flight of 66672, which was technically known as Mission 3-65-97. Research on this one took awhile because there were no pre-flight or inflight photos taken on the day of Adams’ flight. I consulted with X-15 authors Michelle Evans and Dennis Jenkins, and both were very helpful. With their information, I used an existing card model of 66672 and added scratchbuilt detail to model the last flight.
On flight 3-65, 66672 carried a number of experiments in wingtip pods and an experiment box at the rear of the upper tail. The most colorful of the experiments was a test section of insulation intended for the Saturn V rocket; it was attached to the upper left speed brake. The vehicle also sported the knife-edge leading edge attachment to the upper rudder that was fitted on 66672 late in its life.
I scratchbuilt the wingtip pods out of paper lollipop sticks. The experiment box and the Saturn V insulation panel were scratchbuilt from scrap cardstock. I also scratchbuilt the jettison tubes and other bits and pieces. I will probably add some weathering in the next day or so.
