Zoids: How do I remove Acrylic ?
    November 2003
Posted by MartianGundamModeler on Wednesday, November 19, 2003 12:53 AM
I recently purchased a Holo Tech Zaber Fang from the Zoids line of "action figure model kits" on clearance for $5. It is a robotic saber toothed tiger molded in semi-transparrent yellow plastic which at the time I considered as just a gimmic by Hasbro to rerelease an old mold and resell an old model. Anyway i began painting it with craft store acrylic paint to practice brush painting on larger areas and it was coming along nicely but now the model has made an appearance on the show as some sort of "stealth zoid" and I now wish to undo what i have started. I have only painted one leg, most of the head, and a body side panel. Is there a way to remove the paint without damaging the semi-transparent plastic [aside from scaping it off with a finger nail!LOL]?
"Some men look at things the way they are and ask ' Why?'. I dream of things that never were and ask "Why not?".--Robert Kennedy taken from George Bernard Shaw's "Back To Methuselah" (Thanks to TomZ2) http://martiangundammodels.50megs.com/index.html
    June 2003
Posted by Gundamhead on Wednesday, November 19, 2003 2:29 AM
Go to the hobby store and buy a product called E.L.O. (Easy Lift Off) from Polly S paints. It's a modeler's paint stripper. Brush it on, wait 5 minutes and scrub the paint off easily with a old tooth brush. Wash it off with warm soapy water and you're done.
Posted by Anonymous on Wednesday, November 19, 2003 2:52 AM
For a cheaper alternative, I've been using Simple Green. Used straight from the bottle, it will take the paint off of just about anything. Apply a small amount, wait for a minute or so, and then scrub off the paint. I've never seen it damage any of my kits, but some plastics may be harmed by longer exposure. If in doubt, always test on a piece of sprue or part that you don't need.
demono69
    November 2003
Posted by MartianGundamModeler on Wednesday, November 19, 2003 3:34 AM
There is a new thread in the automotive subjects that mentions brake fluid [among others]. would that also work for this application?
Where is "simple green" found, is it the same as a product called "Mean Green" which is often found at Dollar General and Family dollar stores?
    June 2003
Posted by Gundamhead on Thursday, November 20, 2003 5:16 AM
The problem with brake fluid is it's dangerous (hydraulic fluid is bad stuff) and takes a stonger bath to degrease the kit afterwards. Simple Green is astrong detergent and can be found in hardware stores and even some department stores.
    November 2003
Posted by MartianGundamModeler on Thursday, November 20, 2003 5:25 AM
Thanks for the warning! i think i will stay away from that stuff.LOL I'll see if I can find this Simple Green stuff. How long do you soak in the simple green?
