Modifing Iron Man Kit. Finished!!!
    August 2003
Posted by RoyFokker on Saturday, November 28, 2009 12:47 AM
I restarted my Iron Man Kit, I have the left leg bend finished Its not as bent out as far as I wanted it, but I think it looks good I used epoxy putty to fill in the knee where I bent it, front and back. The blue tape is holding the upper hip so I can test fit the finished leg. And here's the left leg test fit, I wanted to see if it would balance and it did [8D] but im going to need to slightly rase the left leg to the same height as the cardboard you see below the left leg
I have the leg bend done, Now to the left arm.   http://farm5.static.flicker.com/4018/4289046362_803f24bb1b.jpg
Thank You For LookingBig Smile
"Untill That Board of Inquirey, I'm Still Captain! First, Find Cyrano Jones! And Second. Close That Door!"
Posted by Swanny on Saturday, November 28, 2009 8:02 AM
Glad to see you are back to this one, I was starting to wonder what had happened. It's looking very good and I am really looking forward to seeing it finished.
    September 2009
Posted by Cobra 427 on Saturday, November 28, 2009 3:10 PM
This is very cool! I want one of these,but right now I have all on my plate that I handle. I suppose this will be lighted?
Maybe a picture of a squirrel playing a harmonica will make you feel better?
    August 2003
Posted by RoyFokker on Saturday, November 28, 2009 3:46 PM
Thank You Smile [:)]
I would love to but after all the modifing I have done and still need to finish I dont think I will be lighting my Iron Man
    August 2003
Posted by RoyFokker on Saturday, November 28, 2009 4:52 PM
I just about have Iron Man's arm finished! Here you can see that I shortend the neck, But I think I need to add a little to the neck because I made it just a little to shortBlush [:I] At the moment I need to hold the left arm, for now! I still need to build the support for the arm, But it looks cool! Here's a look at the arm, I need to add the wrist armor and I need to fill the open spots at the elbow that are now open after I changed the Left arm.  I case your wondering how I have the upper and lower arm together with out glueing them together yet, with out the tape anyway? The strine I beam extends into the lower arm and it squezes around the hole and peg in the lower arm, its a goog tight fit! In this picture you see a slot in the upper arm I added an extention off the same strine I beam to help support the arm when I mount it.
My last shots, for now! On top of the helmet there's a slot  After looking at some pictures I notest that it extends all the way to the back, and that there's also armor protecting the back of the neck
Thank You for lookingBig Smile [:D]
    August 2003
Posted by RoyFokker on Thursday, March 18, 2010 1:48 AM
O my gosh! Sorry I havent kept up with my updates!  I almost have my Iron Man kit finished!  Here are my latest shots.  Here you see finished left arm.  Almost ready to glue it together, test fiting the left arm.
sorry this is so Big, but its hard to see the small details on the chest piece, I couldent find anything thiner than the index card I had so I used it for the cross bars. the rest is sheet strine and string.
  Buliding almost finished, and now to fill some gaps.      Arm attached, gaps filled, building finished.  And now-
for a primer cote of steel,  I tested the paint's i'm going use on a scrap of sheet sterine. I figured out that if I paint a primer cote of steel under Stop Light Red metallic it looks great, But I just painted it on a part of the heltmet and it looks alittle light so I tested a mix of 3 parts of Stop light red and 1 part of Flat black. It looks a lot closer to the paint job form the movie. After reading in the instructions thay want you to paint Gold on certain area's. I made a mix of 2 parts Gold and 1 pare Brass and I think it looks a lot closer to the Movie Iron Man.
Thank You for looking.Big Smile
    August 2003
Posted by RoyFokker on Tuesday, March 23, 2010 6:34 PM
I have finished the Red paint job on my Iron Man. I decited to paint a base cote of Aluminum under the Gold parts, because most of parts are still putty green.
The Red looked so good after I finished it I decited to paint the Gold face mask.
Thank You For Looking Big Smile
    September 2009
Posted by Cobra 427 on Wednesday, March 31, 2010 5:25 PM
This is amazing! I've been waiting for this update.  This is the best figure build yet! I hope this will be lighted. Thank you for sharing this with the rest of us.
        ~ Cobra Chris
    August 2003
Posted by RoyFokker on Wednesday, March 31, 2010 6:25 PM
Thank You.  I would have loved to light up my Iron Man!  But with all the modifying ive done and its a little late to do anything about it now.Stick out tongue  But I have some painting techniques that will make it look good.
    August 2003
Posted by RoyFokker on Monday, April 5, 2010 12:14 AM
Unless something happens. I've finished my Iron Man paint job Cool  Now just need to finish a few fiinale details, And the base.
 Alittle big but its a preaty good shot, I think
Thank You for Looking
    August 2003
Posted by RoyFokker on Wednesday, April 14, 2010 2:08 PM
I have finished my modifyed Iron Man Big Smile.  I used scale railroad ballest on my base to try to match the movie scene and I really think I nailed it.
After I had all of the ballest on and was looking good I rememberd there was ash or snow falling in the secne, I saved some from sanding the epoxy puddy I used to fill in some spots, and I used it to make the snow / ash on the gound.  I made some brickes from some extra epoxy puddy I had left over.  Last shot, you can see I added some detail under the left arm, It look good and it filled the hole that was there.  Thank You for Your Time Big Smile .
Posted by Swanny on Wednesday, April 14, 2010 2:34 PM
That is just a super build. Magnificent job.
Posted by rjkplasticmod on Wednesday, April 14, 2010 2:37 PM
Very nice Roy Yes.  You're efforts were well rewarded with an outstanding Figure.
Regards,  Rick
Posted by rossjr on Wednesday, April 14, 2010 3:16 PM
Very nice!  You turned it into a piece of art!!!
How is this?  My son did his for a recent show...
http://i255.photobucket.com/albums/hh137/cougar184cr184/ironman%20final/DSCF1964.jpg
    August 2003
Posted by RoyFokker on Wednesday, April 14, 2010 6:12 PM
Thank You everybody Big Smile       Rossjr Thats an Incridable job!!  Looks big, Is that a costume?
Posted by rossjr on Thursday, April 15, 2010 12:18 PM
Yes it's my son's he wears it at special events and comic book conventions.  We used it for his Iron man model at contest in February....   He'll have it at WonderFest this year...
His model wan't nearly as nice as yours though...
    August 2003
Posted by RoyFokker on Thursday, April 15, 2010 6:45 PM
Its still really impressive!!  I was hopeing that I would get my model kit done before Iron Man 2 comes out.
Mr Stark shure did up grade his armor on his Mk V suit.
