Moebius BSG Viper Mk.II complete
Moderator
    April 2006
  • From: my keyboard dreaming of being at the workbench
Posted by Aaron Skinner on Wednesday, June 16, 2010 2:55 PM
Guys,
Love this ship and this model! I built it for FSM Workbench Review; look for it in September. Meanwhile, let me know what you think. Critiques and comments welcome.
Cheers, Aaron
Aaron Skinner
Editor
FineScale Modeler
    March 2006
Posted by TD4438 on Wednesday, June 16, 2010 4:25 PM
Looks great.Got any shots of the bottom detail?Everybody over looks that.
    October 2009
Posted by Ti4019 on Thursday, June 17, 2010 8:03 AM
Aaron isnt this a fun model to build? Quick ,too!
Did you use the kit decals for the stripes? What setting solution did you use?
4438 just like the real thing there isnt much down there other than the landing gear doors. MLG and NLG looks okay. The two round access panels and oblong panel at the kerf are present like the full size prop.  Aft engine detail is wrong so that will need to be fixed. This is about all you see from the front/bottom if you dont use the gear.
http://www.modelermagic.com/wordpress/wp-content/uploads/2009/06/dscn0561.jpg
If you aren't having fun, you're doing it wrong! Build to please yourself and they will flame you every time!
Moderator
    April 2006
Posted by Aaron Skinner on Thursday, June 17, 2010 8:50 AM
Ti4019,
I painted my stripes because I wanted to use a little salt to chip the paint. Plus I wondered how well the stripes would conform over te engine section under vertical stab. Of course, masking that was no picnic.
Cheers, Aaron
Aaron Skinner
Editor
FineScale Modeler
    October 2009
Posted by Ti4019 on Thursday, June 17, 2010 10:23 AM
Thanks Aaron
yes masking was a chore but worth it when I pulled the tape off. All the prep paid off almost zero underspray. I sealed the tape with my base coat mix.
I used British Crimson, what did you use? I didnt salt it, I will on the next.
Moderator
    April 2006
Posted by Aaron Skinner on Thursday, June 17, 2010 10:32 AM
Ti4019
Thanks Aaron
I used insignia red. I rushed my masking more than I should have, and got some underspray in a few areas. Weathering and touch up took care of most of the issues.
Aaron Skinner
Editor
FineScale Modeler
    January 2009
Posted by Division 6 on Thursday, June 17, 2010 1:58 PM
Looks good.
As for the details being off from the studio set piece, this model is based on and probably used the digital models from Zoic.
The tells are the back end and the horizontal side slots on the forward fuselage.
On the CG model there are small fans in the lower rear, the set piece has lots of tubing and a push bar for the stage crew to move it around with and the side details have the (4) vertical strips flush top and bottom where the set piece has them inset and curve inward at the top.
If you look really closely at the model you can see the forth one just barely.
There are also issues with the ejector seat and a few missing details in the cockpit also the joystick panel in the center does not go all the way to the seat and there is a small red light on the back left side panel.
If you are using the PE set than part "5" needs to be cut into 3 pieces and the second (middle piece) gauge needs to be rotated 90 degrees clock wise also the long slot on the part with the switches needs to be cut out if you are lighting it since there is a red LED clock in there.
If anyone needs pix let me know.
Also on the SyFy website they have a virtual  tour of the Galactica and if you can find your way to the hanger you can sit in and look around the cockpit of both the Mk2 and Mk7.
Eric...
    December 2007
Posted by Cosmic J on Friday, June 18, 2010 4:02 AM
Wow. That's a nice looking Viper there.
I really like what you did w/ the engines - could you tell us how you painted and weathered them?
Moderator
    April 2006
Posted by Aaron Skinner on Friday, June 18, 2010 8:49 AM
Cosmic J
I base-coated with Model Master Metallizer gunmetal. Then I sprayed a light coat of stainless steel inside the feathers and the base of the exterior of the cans feathering to toward the open end. I dry-brushed metallic gray, washed with a dark brown artist's oils. Finally, I applied weathering powders: sooty black outside around the opening, then a light gray ash color between the feathers inside.
Cheers, Aaron
Aaron Skinner
Editor
FineScale Modeler
    June 2009
Posted by Guney on Tuesday, June 22, 2010 4:34 PM
Looking good...Well done Aaron.....:)
    December 2009
Posted by britjeff on Friday, June 25, 2010 2:41 AM
looks sweet that aaron. loved bsg as a kid growing up in Kuwait, even had the die cast viper and cylon ship. take it this kit is from the new bsg? have to try and get one. once again very nice.
jeff
Posted by aardvark1917 on Friday, June 25, 2010 7:21 AM
Division 6
If you are using the PE set than part "5" needs to be cut into 3 pieces and the second (middle piece) gauge needs to be rotated 90 degrees clock wise also the long slot on the part with the switches needs to be cut out if you are lighting it since there is a red LED clock in there. ...
Who makes the PE for the kit?
"Freedom is a possession of inestimable value." -- Marcus Tullius Cicero
    January 2009
Posted by Division 6 on Friday, June 25, 2010 10:43 AM
ParaGrafix Modeling Systems
Can be found at the Starship Modelers store
CultTVMan store
Mega Hobby
    May 2005
Posted by terry35 on Saturday, June 26, 2010 7:49 PM
Aaron that is one super looking viper. Jst got one myself and am sitting watching the tv series on disc as I type. Can't wait to start this baby, thanks for the inspiring post.
Terry.
Posted by aardvark1917 on Monday, June 28, 2010 11:57 AM
How big is this thing compared with other planes? Could you stick it next to something similarly sized and photograph it?
    October 2009
Posted by Ti4019 on Monday, June 28, 2010 1:21 PM
just off the top of my head my Tamiya F4F Wildcat is in the same rough size.
my kit DOES fit inside a shoebox with room and padding but it is not tiny by any stretch.
Moderator
    April 2006
Posted by Aaron Skinner on Monday, June 28, 2010 1:39 PM
aardvark1917
I'll see about a photo, but right now I can tell you that it's on my desk next to a 1/32 scale P-47. The fuselage is a couple inches shorter and there aren't a lot of wings involved so you get the idea. That said it looks great and isn't a shrimp on the table.
Cheers, Aaron
Aaron Skinner
Editor
FineScale Modeler
Posted by TANGO 1 on Wednesday, June 30, 2010 7:01 PM
Looks Awesome!!Bow DownBow DownBow Down
I love the way you weathered this Viper, excellent build!
Regards, Darren. C.A.G. FAA/USNFAW GB
    December 2007
Posted by Cosmic J on Thursday, July 1, 2010 3:07 AM
When I watched the new BSG series, I have to say that I was not a fan of the MkII Viper design, but I may have to revise my opinion.
 The original series Vipers had this sort of brutal simplicity. They were raw and stripped down war machines – a cockpit and some guns bolted on to some huge engines, w/ minimal control surfaces. An uncomplicated, efficient machine, designed to murder Cylons en masse. Awesome.
I thought the newer ones however, were kind of… I don’t know… sporty. A bit fancy. Too much design effort in making it look cool, rather than aiming for efficiency.
 That said, looking at this little fighter in recent threads like this, I’m beginning to see the appeal. The large cockpit is especially interesting, and as I said up thread, I’m digging those engines.
Looking forward to the review.
Posted by aardvark1917 on Sunday, July 4, 2010 12:03 AM
Found the instructions for using the PE, should anyone be interested.
    January 2009
Posted by Division 6 on Sunday, July 4, 2010 1:10 PM
Here's a little photoshop job of what  I was talking about earlier about the PE part on the right side.
Part 6 should be rotated as well as you can see on the picture on the right with the arrow.
    October 2009
Posted by Ti4019 on Sunday, July 4, 2010 6:55 PM
nicely done!
